Some ideas to differentiate between NUM (home) and CAS
07-28-2018, 01:58 AM
Perdon (electronic translation)
The report of users who handle the hpprime, is that they do not understand the separation between HOME and CAS
1: When you press the [HOME] key, show in the title the NUM (NUMERIC INTERFACE), to differentiate it from CAS (SYMBOLIC INTERFACE)
2: Press the SHIFT + 4 (program) key to label after the program name, according to type (NUM) O (CAS)
2.1: By pressing the [more] [sort] key, add a new menu: sort by type, either (NUM) or (CAS)
2.2: Pressing the [enter] key places the name of the program or subfunction in the history entry line, since the EDIT function already exists with [EDIT]
3: By pressing the [tools / catalog] (i) title key, you can select what type of list you want to display, that is, only NUMERICAL calculation commands (HOME), SYMBOLIC calculation commands, application commands, user commands
4: When pressing the [vars] key, rename [USER] to [NUM], since the CAS type programs are also user prg
[HOME] [CAS] [APP] [USER] [CATALOG] [OK]
to
[HOME] [CAS] [APP] [NUM] [CATALOG] [OK]
