Magic Square, No Center
07-30-2018, 01:26 PM
This is a slightly revised 4-sided zigzag problem: (see July 2018 little math problem)
This have wonderful symmetries ... ABC H D GFE All sides sum to the same number S Variable values between 1 to 8, all different: Hint: search for as many symmetries as you can. I have an elegant solution, only 12 cases to check (will post later ...) |
07-30-2018, 07:33 PM
(This post was last modified: 07-30-2018 08:11 PM by ijabbott.)
RE: Magic Square, No Center
I get a total of 64 solutions: 4 (fundamental) * 2 (9's complement) * 8 (order of symmetry group of square).
EDIT: I just realized there are fewer than 64 due to overlapping symmetries. I make it 48 solutions now. Code: Spoiler — Ian Abbott |
07-30-2018, 09:44 PM
Hi, ijabbott:
I am glad you do the puzzle the old fashion way, and not "brute force" it. How to do grade this puzzle ... Is it good ? 48 is correct ! (3 primary solutions x 16 = 48) However, some issues before you win the jackpot
Tests should be an even number, due to 9-complement symmetry. 19 does not sound right. |
07-30-2018, 11:41 PM
(07-30-2018 09:44 PM)Albert Chan Wrote: Hi, ijabbott: (I changed your list to a numbered list for reference.)
I missed "12 (1)7(4)6(2)5(5)6" from my check list. — Ian Abbott |
07-30-2018, 11:58 PM
(This post was last modified: 07-31-2018 12:07 AM by Albert Chan.)
Here is my answer to the puzzle.
