EDITLIST
08-10-2018, 04:32 PM
EDITLIST
Bonjour
En lisant l'aide sur EDITLIST, j'ai pensé que l'on pouvait éditer plusieurs listes simultanément. Puisque l'on parle de noms de colonnes. Mais je n'y arrive pas. J'ai essayé : Code:
Hello Reading the help on EDITLIST, I thought we could edit several lists simultaneously. Since we are talking about column names. But I can not. I tried : Code:
But I end up with 2 lines that contain l and m and a single column ? Sorry for my english |
08-10-2018, 11:30 PM
(This post was last modified: 08-10-2018 11:41 PM by roadrunner.)
RE: EDITLIST
Indeed, edit list does not seem to function as advertised. EDITMAT does however; perhaps you could use list2mat, EDITMAT, and mat2list instead:
Code: EXPORT eraseme() -road |
08-11-2018, 04:53 AM
(This post was last modified: 08-11-2018 04:53 AM by Tyann.)
RE: EDITLIST
Bonjour
Convertir des listes en matrices est une bonne idée Merci. Cependant si les listes contiennent des chaînes de caractères cela ne pourra pas se faire. Mais oui pour des valeurs numériques c'est une possibilité. Hello Converting lists to matrices is a good idea Thank you. However if the lists contain strings this does not can not be done. But yes for numerical values is a possibility. Sorry for my english |
