One-Line Exact CAS Fibonacci?
09-01-2018, 06:40 PM
In Home, generating successive members of the Fibonacci Sequence with each press of the Enter key, without using variables, is as simple as this:
![]() However, Home is limited to 12-digit mantissas, so the above is only accurate up to 10^12. My question is: Is it POSSIBLE to accomplish the same goal (generating successive members of the Fibonacci Sequence with each press of the Enter key, without using variables) in CAS, thereby allowing exact results > 10^12? (The above method fails in CAS because Ans(2) has a different meaning in CAS.) If possible at all, how many ways are there of doing it? If the use of variables is required, can just one variable suffice? I found a solution that uses the undocumented command 'bloc' but it's fugly and uses two variables that must be initialized first. ![]() N.B. Yes, Fibonacci has been discussed MANY times here before, but AFAIK never in terms of the specific goal described above, for the HP Prime. <0|ɸ|0> -Joe- |
09-01-2018, 07:15 PM
RE: One-Line Exact CAS Fibonacci? | |||
09-01-2018, 09:38 PM
09-01-2018, 11:15 PM
09-02-2018, 02:15 AM
[[1,0]]
or is it [[1],[0]] I can't tell because of the template - it looks like this ||1|| ||0|| then list2mat({Ans(2,1),Ans(2,1)+Ans(1,1)},1) [ ENTER ] [ ENTER ] VPN PS: What picture service should I use - all that I tried failed *I can't remember ... Tumblr? HP Prime Matrix |
09-02-2018, 03:25 AM
(09-01-2018 07:15 PM)Didier Lachieze Wrote: With one variable : Based on Didier's single variable solution, this shows [n, F(n)]: a:=0 [1,1] [((Ans(1)+1),(a+(a:=Ans(2)))] Ceci n'est pas une signature. |
09-02-2018, 03:27 AM
Wow, these are all cool! I didn't even know that a+(a:=Ans) was a valid statement! Yowza!
My fugly solution that uses two variables: Setup: a:=1 b:=1 Command line: bloc((b:=a),(a:=b+Ans),a) <0|ɸ|0> -Joe- |
09-02-2018, 08:04 AM
09-02-2018, 12:07 PM
(09-02-2018 08:04 AM)Didier Lachieze Wrote:(09-02-2018 03:27 AM)Joe Horn Wrote: Command line: Oh yeah. Oops. ![]() <0|ɸ|0> -Joe- |
