(12C) Check if given number is Fibonacci number
09-04-2018, 11:58 AM
(This post was last modified: 09-04-2018 01:51 PM by Gamo.)
Program to check if a given number is Fibonacci Number or not.
Procedure: Yes display 1 No display 0 Example: 377 [R/S] display 1 // Yes this is Fibonacci Number 234 [R/S] display 0 // This number is not Fibonacci Number 987 [R/S] display 1 Program: Code:
Gamo |
09-04-2018, 02:00 PM
RE: (12C) Check if given number is Fibonacci number
Nice formula:
If (5 x^2 +/- 4) is perfect square, x is Fibonacci number. However, there is a weakness if done on the HP-12C. For x > 44721, the expression overflow 10-digits. Rounding errors kill the algorithm. So, above code has a safe domain upto 44721 (only 23 Fibonacci numbers in that range) It might be better to generate the Fibonacci numbers directly, and test the input. |
09-04-2018, 02:25 PM
Thanks Albert Chan
Good idea. I was thinking about other ways to do this. Let's see if anyone got any other ways to do this better. Thanks Gamo |
09-07-2018, 03:19 PM
Hello, Gamo!
About overflow problem. I suggest alternative algorithm. In Binet's formula the second term tends to zero when n → ∞: ((1-√5)/2)^n → 0 So, we can approx F_n with only first term and check that estimated n is close to integer number. n ∼ (ln(√5) + ln(n)) / ln(phi), phi = (1+√5)/2 I write small Python3 script and checked that this approach is correct for all arguments > 1 up to 10^10. In program n means number to test. Function is_fib1 implements your algorithm (without overflow due to integer numbers in Python is dinamically sized). I think, it may be programmed on calculator. Code:
09-07-2018, 07:33 PM
(This post was last modified: 09-08-2018 09:10 PM by Albert Chan.)
Hi, stored
Good job ! HP-12C does not have the precision of Python float (~ 15 decimals) It failed with Fib(40) = 102334155, see First 300 Fibonacci Numbers But, if you use <= eps, instead of < eps, it barely squeezed thru. BTW, you do not need to check all possible X's. Since the code is fitting n as a straight line, n ~ 1/ln(phi) * ln(X)+ ln(sqrt(5))/ln(phi), only range of Fib(n) +/- 1 for confirmation is enough. Edit : < eps passes Fib(40), if use form: n = ln(X)/ln(phi) + ln(sqrt(5))/ln(phi) ~ ln(X)/0.4812118252 + 1.672275938 Test can be simplifed as IS_FIB = int(n + 1/X) - int(n - 1/X), where 0=False, 1=True |
09-08-2018, 06:48 PM
Hello, Albert!
Your remarks is correct and very useful. Thanks you. |
09-09-2018, 12:14 AM
(This post was last modified: 09-09-2018 01:35 AM by Albert Chan.)
Hi, stored
To extend your algorithm for full ten digits (your code take care of eight), I use Binet formula. Instead of guessing n from X, do it in reverse, with HP12C correction to match actual Fib(n): X = phi^n / sqrt(5) X = X - X * 7.7e-9 X = INT(X + 0.5) For n>40, if your code think the number may be Fibonacci, above can check it. note: eps = 2e-8 may cover this range, but need actual confirmation. |
