Simplify e^(i*ln(x))
09-13-2018, 02:00 PM
Is there any function on the CAS to turn e^(i*ln(x)) into x^i?
I tried exp2pow which should do exactly that and it does nothing. I have tried it in complex mode as well.
Thanks for any help.
09-13-2018, 08:03 PM
RE: Simplify e^(i*ln(x))
exp2pow does not rewrite as power if the argument of the exp is not real, because x^i can only be defined using exp(i*ln(x)).
