STRINGFROMID and gradians
09-18-2018, 08:13 AM (This post was last modified: 09-18-2018 08:14 AM by Didier Lachieze.)
I would like to display the current angle mode in the current language. Using STRINGFROMID(21) I get the current language translation for Radians, and with STRINGFROMID(22) I get it for Degrees, but I can’t find the ID for Gradians.
Could it be that as the gradians were a late addition to the Prime, the STRINGFROMID maximum ID value (2996) was not updated to include the new strings?
09-18-2018, 03:46 PM
RE: STRINGFROMID and gradians
STRINGFROMID(2193)
-road
09-18-2018, 04:10 PM
Not really, I expect to get "Gradians" in English, "Gon" in Deutsch, "Grades" in French ... (what is displayed in the Home Settings), but with STRINGFROMID(2193) I just get "Gradient" for these languages.
09-18-2018, 04:22 PM
My bad. I wrote a little program to find it, but misspelled Gradians and found Gradient instead.
-road
09-18-2018, 04:39 PM
(09-18-2018 04:22 PM)roadrunner Wrote:  My bad. I wrote a little program to find it, but misspelled Gradians and found Gradient instead.
-road
Could you kindly share your little program, please?!
09-18-2018, 05:09 PM
EXPORT cs()
X:=2996;
WHILE X>=0 DO
IF STRINGFROMID(X) == "Gradient" THEN
PRINT(X + " " + STRINGFROMID(X));
X:=X-1;
09-19-2018, 02:24 AM
A small update to this program and I found it is 1628.
STRINGFROMID(1628)
English: gradian
French: grade
Spanish: gradianes
EXPORT cs()
X:=2996;
WHILE X>=0 DO
IF INSTRING(STRINGFROMID(X),"rad") > 0 THEN
X:=X-1;
Ceci n'est pas une signature.
09-19-2018, 04:07 AM
It's close but it's not the string used in the Home Settings, look at German for example.
09-19-2018, 05:02 AM
Bonjour
Pour afficher le mode angulaire en clair, j'utilise STRINGFROMID(1626+HAngle)
cela fonctionne pour le Français, l'Anglais, l'Espagnol.
Mais pas pour l'allemand peut-être un problème de traduction.
Hello
To display the angular mode in clear, I use STRINGFROMID (1626 + HAngle)
it works for French, English, Spanish.
But not for German may be a translation problem.
Sorry for my english
09-19-2018, 06:31 AM (This post was last modified: 09-19-2018 06:36 AM by Tim Wessman.)
STRINGFROMID("Modes_Gradian")
Yes, there currently is no utility in the system to let you search the strings...
You are correct that the old number based input stopped at a certain point. (specifically, when we switched to using the new language resource files 2 years back or so). To provide backward comparability on the change, we linked them together at that time in a little table.
Part of why that utility hasn't been turned on was we really wanted to get some cleanup done in the string names as in some cases they are out of order, named with spelling mistakes, etc and once it was public they'd be locked in. Probably not worth the time to do that cleanup though.
TW
09-19-2018, 06:38 AM
Thanks Tim !
It works also for STRINGFROMID("Modes_Radian") and STRINGFROMID("Modes_Degree") and other modes... a built-in utility to search the strings would be great.
09-19-2018, 07:03 AM
STRINGFROMID(number) is depreciated and should not be used anymore...
The main issue is that doing it this ways forces us to continue using the same numbering scheme that we created 10 years ago for the 39GII+... Not a good thing...
2~3 years ago we moved to a new/different scheme that allowed us to easely add/change/modify strings.
We also changed STRINGFROMID to use strings as IDs...
But this has not been widely announced :-( sorry about that...
Anyhow, strings are now separated in 40 "groups" and a string ID is a string composed of the group name, an underscore character and a string ID...
For example: "Main_CANCEL"...
Only problem: How would the user know/find these IDs????
Well, That is another problem and I will try to fix it in a future release...
In the meantime, please find attached the "list" of all groups and IDs.
Each list here starts with a group name and then lists ALL the IDs in said group.
Cyrille
Attached File(s)
.txt  stringfromids.txt (Size: 52.86 KB / Downloads: 43)
09-19-2018, 08:12 AM
Note that these string names are NOT final and guaranteed to be supported long term. For example, in the "modes" group there are a bunch of spreadsheet items that need to be moved.
Once that happens, the string name will have changed. The upside will be that we'll be close to allowing users will then be able to make new language translations or modifications to existing ones. Smile
TW
09-19-2018, 03:53 PM
(09-19-2018 07:03 AM)cyrille de brébisson Wrote:  X
Cyrille
Great!
Into my mid come hold [Shift] [Vars]
but then you would have to implement a hold-Shift functionality
Remember the old HP 49/50 hold-shift keylevels with keynumber nn.xy
where x is the used shift key and y is the hold
09-19-2018, 04:10 PM
(09-19-2018 08:12 AM)Tim Wessman Wrote:  Note that these string names are NOT final and guaranteed to be supported long term. For example, in the "modes" group there are a bunch of spreadsheet items that need to be moved.
Well, that would be a massive improvement!
I remember the days I made a Finnish translation of the main error messages in SysRPL.
Then the OS msg handling changed, but JYA helped to change the source code accordingly.
The new inner handler secrets thus remained secret.
The free FINLIB49 still has both of our names in the Copyright splash screen.
09-19-2018, 10:10 PM (This post was last modified: 09-19-2018 10:15 PM by Didier Lachieze.)
Thanks Cyrille & Tim !
Leveraged from this program, here is a new program to generate text files for the different languages including the Group_ID and the related string in the language locale.
For each group the IDs are sorted by alphabetical order.
EXPORT STRINGFROMID_TXT()
LOCAL li,header,group,id,j,k,str;
LOCAL Tx,Nmb,lg,id_list;
li:={
{"Main","None","STO","CANCEL","OK","PAGE","EDIT","CHOOSE","CHECK","CHECKCHAR","ModesEnglish","ModesFrench","ModesChinese","ModesJapanese","ModesRussian","COPY","SHOW","SAVE","RESET","SORT","SEND","START","AppsTitle","AppSortAlpha","AppSortChronologicaly","AppSortGrouped","AppSortTitle","Program","END","String","ALL","UserApps","EVAL","InvalidInput","DELETE","TITLEChooseNewNameforApp","HELPAPPChooseNewName","BEGIN","Name","AreYouSureYouWantToDeleteThisApp","ClearAllExpressions","Help","PASTE","StreamerPressAnyKey","PressAnyKeyToGetHelp","Key","TREE","AreYouSureDeleteAllApps","ProgramHadAnError","SymbView","PlotView","NumView","SymbSetup","PlotSetup","NameAlreadyInUse","Variable","ClearMemory","FullMemory","NoConnection","CancelOp","AreYouSureResetThisApp","CLEAR","CUT","LINE","ModesDeutchland","ModesEspana","ModesNetherlands","ModesPortuguese","DebugSkip","DebugStep","DebugStop","DebugCont","AreYouSureYouWantToDeleteThisItem","AreYouSureYouWantToDeleteAllItems","PasteShow","DeviceCommIncompatible","SSCopyValue","SSCopyFormula","SSCopyFormat","SSCopyValueFormat","SSCopyFormulaFormat","DefaultTest","GeomChooseColorTitle","CalendarJanruary","CalendarFebrary","CalendarMarch","CalendarApril","CalendarMay","CalendarJune","CalendarJuly","CalendarAugust","CalendarSeptember","CalendarOctober","CalendarNovember","CalendarDecember","CalendarSunday","CalendarMonday","CalendarTuesday","CalendarWednesday","CalendarThursday","CalendarFriday","CalendarSaturday","BatteryLow","BatteryCritical","HelpOther","HelpFind","HelpFindNext","HelpFindSearchLabel","HelpFindSearchLabelHelp","HelpFindContent","HelpFindContentHelp","HelpExample","TerminalTitle","MatrixSwap","2DClipboardFormat2D","2DClipboardFormatNative","ProgramErrorDuringInit","DebugQuitAndEdit","Backups","BackupDelete","BackupNameHelp","Backup","BackupRestore","BackupRestore1","BackupRestore2","BackupRestore3","BackupDeleteAll","MenuBrowse","Accept","Reject","BaseAppLabel","BaseAppHelp"},
{"ConnKit","TestModePasswordInvalid","ModesDecimalLabel","ModesDecimalHelp","CASVarsVariables","SIZE","StreamerOverwriteExistingData","EXIT","ANoteWithSamenameAlreadyExists","AExamModeWithSamenameAlreadyExists","StreamerWaitingConnection","InsertRow","InsertColumn","DeleteRow","DeleteColumn","DeleteAll","ClearContents","ChangeColor","BackupFile","Backup","BackupSaved","BackupRestored","Restore","Properties","Preferences","Poll","Quiz","ExamModes","SpreadsheetPasteSameSize","Minutes","Hours","Hour","EnableLogging","SelectChannelAuto","Environment","Wireless","WorkingFolder","WirelessSSID","WirelessChannel","Content","Calculators","Backups","Logs","Temp","Polls","QuizFolder","Title","HPName","Build","About","UpdateCalculator","GoToHPDotCom","ExitApplication","SaveTheCurrentItem","SaveAll","SaveAllItems","File","Assesment","Open","GetScreenCapture","Monitor","Refresh","CloneFromHere","CloneToHere","SendToClass","CheckForUpdate","Window","Class","Toolbar","Ready","PreferencesSaved","SelectColor","UpdateCheckOnline","UpdateNotNow","CheckForUpdateAuto","UpdateUnconnected","UpdateHostLookup","UpdateConnecting","UpdateConnected","UpdateLoggingIn","UpdateClosing","UpdateDownloadError","UpdateManualDownload","UpdateCouldNotConnectToServer","UpdatePleaseCheckInternet","Done","UpdateConnectingToServer","Downloading","DoYouWantToSave","NewList","NewNote","NewProgram","NewExamMode","NewQuiz","NewPoll","Message","SaveImage","ImageFormatString","ImageSize","SendMessage","CopyToClipboard","SaveAs","Project","Large","Medium","Small","ScreenCapture","Close","ScreenCaptureBorder","ScreenCaptureSize","UpdateDoYouWantToDownload","UpdateNoUpdatesAvailable","AppVersion","OSVersion","BootloaderVersion","SerialNumber","DoneFWUpdate","FWUpdateFileCheckError","FWUpdateRenameFailed","FWUpdateNewFileError","FWUpdate","FWUpdateTimeout","FWUpdateAborted","PQCanGoBack","PQCanExit","PQType","PQQuestion","PQAnswer","PQMultipleChoice","PQNumber","PQPoint","PQExpression","PQText","PQ_ABCDE","PQSelection","PQChoose","PQYesNo","PQTrueFalse","PQTitleLabel","PQLikertScale","PQInstructions","PQQuestions","PQImmediatePopup","ResetHelp","ExamConfigs","Results","Firmware","UpdateFirmware","UserGuide","CloseAll","Tile","Cascade","Initializing","Merge","Replace","AlreadyExists","ReplaceWith","Modified","YesToAll","NoToAll","Next","Previous","Messages","DoYouWantToUpgradeFirmware","PQChoiceALabel","PQChoiceBLabel","PQChoiceCLabel","PQChoiceDLabel","PQChoiceELabel","PQChoiceYes","PQChoiceNo","PQChoiceAgree","PQChoiceTrue","PQChoiceFalse","PQChoiceAlways","PQChoiceSometimes","PQChoiceNever","PQChoiceDisagree","PQChoiceNeutral","PQChoiceStronglyAgree","PQChoiceStronglyDisagree","PQChoiceNotConfident","PQChoice100Confident","PQChoiceOften","PQChoiceRarely","PQLikertTypeAgreeement","PQLikertTypeConfidence","PQLikertTypeOccurance","PQLikertTypeCustom","PQChoice","PQSelectionEditor","AreYouSureYouWantToDeleteThisPoll","AreYouSureYouWantToDeleteThisQuiz","AreYouSureYouWantToDeleteThisResult","AreYouSureYouWantToDeleteAllPolls","AreYouSureYouWantToDeleteAllQuizzes","AreYouSureYouWantToDeleteAllResults","PQCanOnlySendOnce","AutoRefresh","AppStartFailure","Folder","Note","NewFolder","InvalidName","ConKitNetworkCollision","RFOldProtocol","BackupFailed","Update","ConnkitSmallest","AddFile","AddVariable","AddIcon","AreYouSureDeleteThisVariable","AreYouSureDeleteThisFile","ConnkitAppFiles","Documentation","EmulatorUserGuide","EmulatorQuickStartGuide","EmulatorSkinMenu","EmulatorCalculator","EmulatorHideTitlebar","EmulatorVirtualCalculator","SkinCompact","SkinSmall","SkinMedium","SkinLarge","SkinResizing","CalcTypeLocal","CalcTypeWireless","CalcTypeNetwork","CalcTypeUSB","UpdaterSendingFile","UpdaterDoNotDisconnect","UpdaterBrowseForUpdateFiles","UseNewUpdateMethod","NetworkName","NetworkPassword","CalcTypeEmulator","EmulatorVirtualCalculatorShort","ConnkitResultTitle","ConnkitAddBackground","ImageFormatStringJpgFirst","IpNetworking","AllowUpdateWireless","SendOldCalculator","EnableNetwork","ConnkitDragBox","CreateNewContentItem","UpdateMayResume","ResumingUpdate","BetaNotice","BetaUse","BetaReport","VibrateOnTouch","TouchSounds","UnableUpdate","PrimeGraphingCalc","NoPrimeConnected"},
{"Program","ProgramTitle","RUN","Function","Loop","Tests","ValidateMenu","Branch","Drawing","InOut","AppFunctions","NewProgram","ProgrammingCommand","PrgmTemplate","AreYouSureYouWantToDeleteThisPrgm","AProgramWithSameNameExists","TITLESaveProgramAs","NoErrorsInProgram","Block","ProgramParamTitle","DEBUG","PrgmCMDS","TITLERenameProgramAs","CommandPix","CommandCart","ProgramCreateUser","ProgramAddPragma","LabelCASHelp","EncryptedSourceHidden","EncryptedInfoInChoose","CanNotEditEncrypted","ReadOnly","Encrypt","Protection","Bookmarks","EncryptNewName","GOTOLineNumber","GOTOLineNumberHelp","Indent","FormatSource"},
{"HomeSet","ECHO","Complex","List","Matrix","Modes","ExportedUSER","ExportedVariables","Real","VarsHomeTitle","VarsHOME1","APP","VALUE","VALUE1","VarsCASTitle","CAS","CAS1","AppVars","GOTO","Integers","INFO","HELP","HELP1","GotoTitle","GO","GORIGHT","GODOWN","Vector","Matrice","Insert","Delete","MatrixRow","MatrixColumn","Apps","Programs","Notes","Matrices","Lists","Graphics","History","MemoryManager","VIEW","AreYouSureYouWantToDeleteAllNotes","AreYouSureYouWantToDeleteAllPrgms","AreYouSureYouWantToDeleteAllMatrices","ListLibrary","MatrixLibrary","ViewsTitle","ClearList","AreYouSureYouWantToDeleteAllLists","DeleteMatrix","AreYouSureYouWantToClearMemory","SendAll","AreYouSureDeleteCalculationHistory","AreYouSureDeleteUserVars","AreYouSureDeleteCasVars","SelectProgram","INPUTTitle","SYSTEM","DefineNameHelp","DefineFunctionHelp","DefineVarCheckHelp","VarsUserVars","VarsUserFnc","DefineFunction","DefineTitle","DefineNameExists","ContextGetHome","ContextGetCas","ContextMEssaging","RPNStack","RpnDUPN","RpnDROPN","RpnPICK","RpnLIST","RpnROLLD","RpnROLL","BASE","SIGNED","NOT","BaseTitle","BaseWas","BaseOut","BaseHelpEditor","BaseEdit","BaseEditTick","EnterNewValueForVariable","MessagingReplyLabel","More","FreeMemory","FreeStorage","PollIncomplete","PollWarnOneSend","MatrixGotoRowHelp","MatrixGotoColHelp","MatrixSelect","MatrixSelection","MatrixSelectionCheck","MatrixRow1","MatrixRow2","MatrixCol1","MatrixCol2","MatrixSwapRowTitle","MatrixSwapColTitle","MatrixSelectArea","MatrixSelectionSwap"},
{"Chars","Title","ChooseHelp","PageTitle","Latin","LatinSup","LatinExtA","LatinExtB","IPA","SpaceMod","Diacritics","Greek","Cyrillic","CyrillicSup","Armenian","Hebrew","Arabic","Syriac","ArabicSup","Thaana","Samaritan","Mandaic","Unknown","ArabicExtA","Devanagari","Bengali","Gurmukhi","NKo","Gujarati","Oriya","Tamil","Telugu","Kannada","Malayalam","Sinhala","Thai","Lao","Tibetan","Myanmar","Georgian","HangulJamo","Ethiopic","EthiopicSup","Cherokee","UnifCanadianAbSyl","Ogham","Runic","Tagalog","Hanunoo","Buhid","Tagbanwa","Khmer","Mongolian","UnifCanadianAbSylExten","Limbu","TaiLe","NewTaiLue","Buginese","TaiTham","Balinese","Sundanese","Batak","Lepcha","OlChiki","SundaneseExt","VedicExt","PhoneticExt","PhoneticExtSup","ComDiacriticsSup","LatinExt","GreekExt","GeneralPunc","SubsSupers","Currency","DiacSymbs","Letterlike","NumberForms","Arrows","MathematicalSymbols","MiscTech","ControlPictures","OCR","EnclosedAlpha","BoxDrawing","Blocks","GeometricShapes","MiscSymb","Dingbats","MiscMathA","SupArrowsA","BraillePatterns","SupplementalArrowsB","MiscMathSymbB","SupMathOperators","MiscSymbArrows","Glagolitic","LatinExtC","Coptic","GeorgianSup","Tifinagh","EthiopicExt","CyrillicExtA","SupPunc","CJKRadicals","KangxiRadicals","IdeographDescChars","CJKSymbPunc","Hiragana","Katakana","Bopomofo","HangulCompatibilityJamo","Kanbun","BopomofoExtended","CJKStrokes","KatakanaPhonExt","EnclosedCJKLettersMonths","CJKCompatibility","CJKUnifiedIdeographExtenA","YijingHexagrams","CJKUnifiedIdeographs","Yi","YiRadicals","Lisu","Vai","CyrillicExtB","Bamum","ModifierToneLetters","LatinExtD","SylotiNagri","IndNo","Phagspa","Saurashtra","DevaExt","KayahLi","Rejang","HangulA","Javanese","MyanmarExtA","TaiViet","Cham","EthiopicExta","WarangChiti","Beria","MeeteiMayek","HangulSyllables","HangulJamoExtB","HighSurrogates","HighPrivateUserSurrogates","LowSurrogates","PrivateUseArea","CJKCompatIdeog","AlphabeticPresForms","ArabicPresenForms","VariationSel","VerticalForms","CombiningHalfMarks","CJKCompatForms","SmallForm","ArabicPresFormsB","HalfwidthFullwidth","Specials"},
{"Memory","TestModeMenu","ModesFraction","ModesMixedFraction","ModesFormatNbStdHelp","CASDebugTitle","TestModeConfigurationMenuCheck","SaveAs","RECV","InferenceResultLabel","InferenceResultHelp","InferenceFailRejectNull","","InferenceCriticalZHelp","InferenceCriticalSampMeanHelp","InferenceCriticalSampMeanLabelMinHelp","InferenceCriticalSampMeanMaxHelp","InferenceCriticalDeltaSampMeanHelp","InferenceCriticalDeltaSampMeanMinLabel","InferenceCriticalDeltaSampMeanMinHelp","InferenceCriticalDeltaSampMeanMaxHelp","Graphic","Notepad","ExportedUSER1","VarsHOME","APP1","NAME","CASVarsPrograms","Constant","Convert","MathMATH1","MathPHYS1","MathPHYS","INVCROSS","InvCrossHelp","SIZE1","PlotSetup2","VarsFunctions","NumSetup2","InferenceCriticalTPlot","","InferenceTestDeltaPHelp","InferenceTestDeltaMeanHelp","InferenceTestPHelp","","InferenceTestXHelp","InferenceTestZHelp","InferenceCritPPlot","InferenceConf","InferenceConfHelp","InferenceDeltaMean","InferenceP","InferenceDeltaP","InferenceCriticalDeltaMeanHelp","InferenceCriticalDeltaMeanMinLabel","InferenceCriticalDeltaMeanMinHelp","InferenceCriticalDeltaMeanMaxHelp","InferenceCriticalPHelp","InferenceCriticalPMinLabel","InferenceCriticalPMinHelp","InferenceCriticalPMaxHelp","InferenceCriticalDeltaP","InferenceCriticalDeltaPHelp","InferenceCriticalDeltaPMinLabel","InferenceCriticalDeltaPMinHelp","InferenceCriticalDeltaPMaxHelp","","","","SolveAppsSolTypeConstant","","","","CRSymbol","ProgramCommands","Prgm","Prgm1","INS","NewNotes","NewPrograms","StatsS1MarkLabel","StatsS2MarkLabel","StatsS3MarkLabel","StatsS4MarkLabel","StatsS5MarkLabel","StatsEnterUserDefinedFit","","","IncrementAngle","Pi","StatsEnterRowHelp","ClearQuestion","StatsAllCols","SmallFont","MediumFont","LargeFont","WhiteColor","BlackColor","DGrayColor","LGrayColor","BulletLevel1","BulletLevel2","BulletLevel3","Underline","Strikethrough","SuperScript","SubScript","FGColor","BGColor","Bullets","NewProgramHelpLabel","MatrixMatrix","WIDTH1","WIDTH2","WIDTH3","WIDTH4","ColCount","WIDTH","PlotSetupInvCrossHelp","","","SolveNumViewSolList","OverlayPlot","SolveAppsSolTypeExtremum","SolveAppsSolTypeSignReversal","VarsCalculate","VarsStats","VarsSummary","","","","","","","","","","","","","","","","","","","","","","","","StatCalcMinYLabel","","StatCalcQ1YLabel","StatCalcQ1YHelp","StatCalcMedYLabel","StatCalcMedYHelp","StatCalcQ3YLabel","StatCalcQ3YHelp","StatCalcMaxYLabel","StatCalcMaxYHelp","MENUSUMS","MENUSUMS1","ListSize","UnitsConvert","UnitsFunctions","Stat1VarOutlierHelp","Stat1VarOutlierEditHelp","GeomPlotSetupLabelHelp","PlotSetupFunctionLabels","PlotSetupFunctionLabelsHelp","PlotSetupShortcuts","PlotSetupShortcutsHelp","StreamerWaitingReadSensor","StreamerNoSensorDetected","StreamerViewCalibrate","StreamerPlotTypeOverlay","StreamerPlotTypeStack","StreamerFilterAverage","StreamerFilterSingle","StreamerFilterMinimum","StreamerFilterMaximum","StreamerFilterAuto","StreamerFilterWYSIWYG","StreamerCalibrationTitle","StreamerValueLabel","StreamerValueHelp","StreamerDeleteDataPrompt","StreamerEventMethodLabel","StreamerEventLabel","StreamerTimeHelp","StreamerExportStatsTitle","StreamerWidthSecLabel","StreamerWidthSecTitle","StreamerPlotDisplayLabel","StreamerPlotDisplayHelp","StreamerDisplayFillterLabel","StreamerDisplayFilerHelp","StreamerExportFilterLabel","StreamerExportFilterHelp","StreamerHistoryTypeLabel","StreamerHistoryTypeHelp","StreamerHistoryLabel","StreamerHistoryHelp","StreamerFilterFixed","StreamerEnterEntry","StreamerExportNotice","StreamerPROBE","StreamerCH","StreamerZERO","StreamerEnter1or2Points","StreamerPressOKtoAccept","StreamerPressCancelToAbort","ModeHLTColorLabel","ModeSECColorLabel","FunctionSolnNarrowXRNG","FunctionSolnBadXRNGMin","FunctionSolnBadXRNGMax","Stat1VarEnterDataColumn","StreamerChooseSensorTypeHelp","NumDeleteAllRows","LongUndef","ShortUndef","SolvePlotSetupTitle","Stat1VarPlotHRNGNotInterval","InferencePROB","InferencePROB1","StatsFreqSYMBLabel","LinearSolvSetup","SolveAppsSolTypeSingularity","EnterNewProgramsName","Normal","InformationView","CannotEditWithTextSelection","ErrorsInProgram","ReverseConnection","EvalIssue","TemplateMenu","StatisticsFitHelp","AreYouSureYouWantToExitWithoutSavingPrgm","SizeLimitReached","StatisticsLogisticLHelp","StatisticsLogisticCHelp","LINE1","Cata2","FORMAT2","FormatTextLabel","FormatTextSizeHelp","FormatTextFGColor","FormatTextBGColor","TITLERenamePrgmAs","ProgramEnterName","NoteSortChooseTitle","ProgSortChooseTittle","SheetRow","SheetCol","SheetSheet","SheetFormatStringHelp","SheetFormatVAlignHelp","SheetFormatHAlignHelp","SheetFormatForeground","SheetFormatForegroundHelp","SheetFormatBackground","SheetFormatBackgroundHelp","SheetFormatFormula","SheetFormatFormulaHelp","SheetSelectChooseLabel","SheetSelectChooseHelp","SheetSelectRowHelp","SheetSelectColHelp","SheetMenuSelect","SheetFormat","Sheet2DMode","StreamerExportGoStats","StreamerExportFinished","StreamerChooseExportColumn","StreamerDataColumnNotEmpty","StreamerAddedNthPoint","ModesThemeHelp","ModesThemeLabel","ModesColorLabel","Test1p5h","TestUntilMidnight","TestNever","","SSGotoSelHelp","SSGotoSelLabel","ModesTimeSecondHelp","StatCalcSumSqDifOfMean","SSRegrPredX","SSRegrPredY","Operations","Norms","CasRewrite","CasSolve","CasDeriv","GeomZoomUndo","GeomLine","GeomLineVector","GeomLineOther","GeomPolygon","GeomPolygonNgon","GeomPolygonHexagon","GeomPolygonPentagon","GeomPolygonRegHex","GeomPolygonSpecial","GeomPolygonSpecialEqTriangle","GeomCurve","GeomCurveSpecial","GeomCurvePlot","GeomTransform","GeomPoint","GeomPointOther","GeomPointOtherElement","GeomPointOtherTrace","GeomPointOtherErase","GeomPointOtherUntrace","GeomMoveChooseTitle","GeomFunctionsChooseTitle","GeomPlotParamChooseTitle","GeomPlotPolarChooseTitle","GeomPlotSeqChooseTitle","GeomTraceChooseTitle","GeomUntraceChooseTitle","GeomEraseTraceChooseTitle","GeomAttributeChooseTitle","GeomSelectChooseTitle","GeomEraseChooseTitle","GeomVars","GeomVarsTitle","GeomWizard","GeomWizardTitle","GeomChangeColor","GeomToggleCaption","GeomFillColor","GeomHideObject","GeomMoveObject","GeomConfirmClearingTitle","GeomSelectCornerLabel","GeomMoveLabel","GeomPointerLabel","GeomZoomSelectLabel","GeomEnterFunctionExpressionLabel","GeomEnterSequenceExpressionLabel","GeomEnterPolarExpressionLabel","GeomEnterParamExpressionLabel","GeomHitLabel","SSConfStatXlow","SSConfStatXhigh","SSConfStatXmiddle","SSStatStdDev","SSStatRegB","SSStatRegM","SSStatRegX","SSStatRegY","SSStatRegBasicMXY","SSStatTrigFitA","SSStatTrigFitB","SSStatTrigFitC","SSStatTrigFitD","SSStatRegPolyCO","SSStatRegPolyDeg","SSStatRegPolyM","RpnKEEP","Geo3D","BITS","MenuReply","MessagingReplyHelp","MessagingRequestHelp","MessagingRequestConfirmation","ReturnPoll","MessagingCancelRequest","ClassroomNetwork","ConnKitClearAll","ConnKitChat","Remove","TBInverse","TBSchur","TBLncollect","TBPowexpand","TBplotdensity","ImplicitSymbColorSelection","TracingExtrema","ImplicitPlotAddPoint","ImplicitPlotAddPointMsg","ImplicitNumBYOIndepVarXY","ImplicitNumEdgeDefn","ImplicitNumPointsOfInterest","ImplicitNumEdge","ImplicitNumRegion","ImplicitNumAuto","ImplicitNumSat","ImplicitNumNoneSat","TBbarycenter","TBCenter","TBDivPoint","TBelement","TBisobarycenter","TBmidpoint","TBorthocenter","TBpoint2d","TBDrawSlp","TBLineTan","TBaltitude","TBbisector","TBextbisector","TBhalfline","TBmedianline","TBsegment","TBtangent","TBrighttriangle","TBsquare","TBhyperbola","TBcircumcircle","TBlocus","TBhomothety","TBiscoplanar","TBisorthogonal","TBissquare","TBmeasdistance2","ListCount","ExamConfigHelp","WirelessConnect","WirelessDisconnect","WirelessAutoConnect","WirelessConnected","HelpSyntax","ConnKitPQAlwaysSometimesNever","ConnKitPQOptions","ConnKitProjectTimeoutRetry","ConnKitLatestVersion","ConnKitCurrentVersion","ConnKitThisCalculator","ConnKitDoNotAskMeAgain","ConnKitThisSession","ConnKitEver","ConnKitAutoCheckForUpdates","RFDisconnected","ConnKitUpdateFailed","ConnKitUpdateOk","ConnKitRetry","PQShowNames","EmulatorConnectTo","EmulatorHelpFileNotFound","DeprYear","GeoActionsSelectPointEnter","GeoActionSerquenceEnterFactor","","","","","","","","","","","","","","","","RFConnectionHistory","MatrixGotoLabel","MatrixSwapCol","MatrixSwapRow","","","","","","","","","","","","","","","EmpyAppLabel","EmptyAppHelp","DebugSwapPressToReturn","SwapList","InsertItem","DeleteItem","List1","List2","NaN","PlotImageNotFound","PlotSketchNotFunctional","","","","","","","",""},
{"Modes","TestModeConfigurationTitle","OTHER","AngleLabel","FormatLabel","ComplexLabel","Radian","Degree","Gradian","AngleHelp","Standard","Fixed","Scientific","Engineering","Rounded","Float","FormatHelp","FormatNbHelp","Dot","Comma","ComplexHelp","Title","CASModesTitle","CASModesDigitsHelp","CASEvalTitle","CASEvalHelp","CASProgTitle","CASProgHelp","CASEpsilonTitle","CASEpsilonHelp","CASRecursTitle","CASRecursHelp","CASProbaTitle","CASProbaHelp","CASApproxTitle","CASApproxHelp","CASMaxIterTitle","CASMaxIterHelp","CASComplexTitle","CASComplexHelp","CASComplexVarTitle","CASComplexVarHelp","CASIncrPowerTitle","CASIncrPowerHelp","CASAllTrigTitle","CASAllTrigHelp","CASSqrtTitle","CASSqrtHelp","CASIntHelp","CASVerifError","TestTitle","TestConfigurationLabel","TestConfigurationHelp","TestEraseHelp","TestConfigurationUserDisabled","TestMenuConfiguration","TestEraseLabel","TestBlinkHelp","TestBlinkLabel","LanguageHelp","LanguageLabel","Physics","HelpTitleCase","SystemApps","NotesAndPrograms","NewNotesAndPrograms","Mathematics","StatsNoneText","System","ON","OFF","Units","FontLarge","FontMedium","FontSmall","FontHelp","NameHelp","Name","FontLabel","ThemeLabel","ThemeHelp","ThemeLight","ThemeDark","2DHelp","2DLabel","MenuDisplayLabel","MenuDisplayHelp","DefinedAppLeveAM","DefinedAppLeveNF","DefinedAppLeveDM","LanguageSelect","SheetFormatUnspecified","SheetFormatSystemFont","ColorHelp","BaseBin","BaseOct","BaseDec","BaseHex","BaseHelp","BaseLabel","BaseSizeHelp","Test15m","Test30m","Test1h","Test2h","Test3h","Test4h","Test5h","Test6h","Test8h","TestTimeHelp","TestTimeLabel","TestPasswordHelp","TestPasswordLabel","NewTestMode","NewTestModeHelpLabel","AreYouSureYouWantToDeleteThisTestMode","AreYouSureYouWantToResetDefaultTestMode","ClockHelp","TimeLabel","TimeHourHelp","TimeMinHelp","TimeDisplayHelp","TimeDisplayAM","TimeDisplayPM","TimeDisplay24","EntryLabel","EntryHelp","Textbook","Algebraic","RPN","AdvRPN","TestMenuRandom","BitsSignedHelp","ComplexType1","ComplexType2","ComplexDisplayHelp","ExamDefaultAngleLabel","ExamNoChange","ExamRadians","ExamDegrees","ExamDefaultAngleHelp","TBMax","TBMinimum","TBSimplify","DateLabel","DateYearHelp","DateMonthHelp","DateDayHelp","DateFormatHelp","DateFormat1","DateFormat2","DateFormat3","WirelessNetworkProperties","RFVersion","RFUnknown","RFNoAdapter","RFNoNWAvailable","RFNoNWSelected","RFConnected","RFConnecting","RFStatus","CASAutoSimplify","TimeRemaining","FirstDayWeekHelp","InitialConfiguration","FirstRunExampleNumbers","DigitGroupingLabel","DigitGroupingHelp","InOut2","InOut3","USB","RFLookingNetwork","Welcome","ExamModeBasic","ExamModeStopUSB","ExamModeMemoryErased","ExamModeGreenBlink","PressEscContinue","SlideUnlock","Exam_Proctorcode_Code","Exam_Proctorcode_CodeHelp","Exam_Proctorcode_Title","Exam_WarningBox_Line1","Exam_WarningBox_Line2","Exam_WarningBox_Line2_bis","Exam_WarningBox_Line3","Exam_WarningBox_Line3_part2","Exam_WarningBox_Line3_part3","Exam_WarningBox_Line3_part3_2","Exam_WarningBox_Line4","Exam_WarningBox_Title","Exam_Memory","Exam_Memory_help","Exam_Memory_Keep","Exam_Memory_Erase","Exam_Memory_Hide","Exam_Memory_Keep_WipeExam","Exam_Protected","Exam_SendStart","Exam_SendFile","Exam_Proctorcode_TitleHelp","Exam_ProctorMode","Exam_ProctoModeHelp","Exam_ModeExitUsb","ExamModeProtect","ExamNoMemoryChange","ExamClearAfterExam","EnterDateHelp","RfCreateNetworkName","RfCreateNetworkName_NameLabel","RfCreateNetworkName_NameHelp","RfCreateNetworkName_EasyLabel","RfCreateNetworkName_EasyHelp","RfAddNetworks"},
{"AppInfer","MethodLabel","TypeLabel","HypLabel","HypTest","ConfInt","TypeHyp1u","TypeHyp2u","TypeHyp1p","TypeHyp2p","TypeHypT1u","TypeHypT2u","TypeConf1u","TypeConf2u","TypeConf1p","TypeConf2p","TypeConfT1u","TypeConfT2u","Alt1u1","Alt1u2","Alt1u3","Alt2u1","Alt2u2","Alt2u3","Alt1p1","Alt1p2","Alt1p3","Alt2p1","Alt2p2","Alt2p3","MethodHelp","TypeHelp","AltHelp","SampleMeanLabel","SampleMeanHelp","SampleMeanPop1Label","SampleMeanPop1Help","SampleMeanPop2Label","SampleMeanPop2Help","SampleSizeLabel","SampleSizeHelp","SampleSizePop1Label","SampleSizePop1Help","SampleSizePop2Label","SampleSizePop2Help","SuccessCountLabel","SuccessCountHelp","SuccessCount1Label","SuccessCount1Help","SuccessCount2Label","SuccessCount2Help","NullHypPopMeanLabel","NullHypPopMeanHelp","PopStdDevLabel","PopStdDevHelp","Pop1StdDevLabel","Pop1StdDevHelp","Pop2StdDevLabel","Pop2StdDevHelp","SignificanceLevelLabel","SignificanceLevelHelp","RejectNull","CriticalZLabel","CriticalSampMeanLabel","CriticalSampMeanMinLabel","CriticalSampMeanMaxLabel","CriticalDeltaSampMeanLabel","CriticalDeltaSampMeanMaxLabel","AppName","CriticalTLabel","NullHypPopPropHelp","NullHypPopPropLabel","PooledHelp","PooledLabel","Sample1StdDevHelp","Sample1StdDevLabel","Sample2StdDevHelp","Sample2StdDevLabel","SampleStdDevHelp","SampleStdDevLabel","TestDeltaPPlot","TestDeltaPLabel","TestDeltaMeanPlot","TestDeltaMeanLabel","TestPLabel","TestPPlot","TestTLabel","TestTPlot","TestXLabel","TestXPlot","TestZLabel","TestZPlot","CritTPlot","CritZPlot","ConfIntPlot","PLabel","DeltaPLabel","TLabel","XLabel","DeltaMeanLabel","MeanLabel","PiLabel","DeltaPiLabel","ZLabel","ConfidenceLabel","ConfidenceHelp","ConfLabel","Mean","CriticalDeltaMeanLabel","CriticalDeltaMeanMaxLabel","CriticalPLabel","CriticalPMaxLabel","CriticalDeltaPLabel","CriticalDeltaPMaxLabel","ALPHA","ALPHA1","ALPHAEQ","CONF","CONF1","CONFEQ","InferValueBetween0_1","InferValueMustBeGT0_Integer","InferValueMustBePositive","DFLabel","InferValueMustBeGT1_Integer","StatCalcCorrLabel","StatCalcCorrHelp","StatCalcCoefDetLabel","StatCalcCoefDetHelp","MENUCALC","Chi2Method","Chi2GOF","Chi22Way","Chi2Help","Regression","RegressionHelp","RegrLinTTest","RegrConfSlope","RegrConfInt","RegrConfMeanResp","InfrenceRegrPredicInt","Chi2Prob","Chi2Count","Chi2ProbLabel","Chi2ProbHelp","Contrib","Contrib1","Exp","Exp1","LinTAltNE0","LinTAltGT0","LinTAltLT0","MinSlopeHelp","MaxSlopeHelp","MinIntHelp","MaxIntHelp","MeanRespLabel","PredIntervalHelp","MeanRespMinHelp","MeanRespMaxHelp","Anova","AnovaOneWay","AnovaHelp","AnovaDFHelp","ProbHelp","CriticalTHelp","","","","","AnovaMSLabel","AnovaMSHelp","AnovaSSErrLabel","AnovaSSErrHelp","AnovaMSErrLabel","AnovaMSErrHelp","AnovaDFErrLabel","AnovaFLabel","AnovaFHelp","AnovaSSLabel","AnovaSSHelp","Chi2ScoreLabel","Chi2ScoreHelp","LinTBeta1Label","LinTBeta1Help","LinTBeta0Label","LinTBeta0Help","SerrLineLabel","SerrLineHelp","SerrSlopeLabel","SerrSlopeHelp","SerrInterLabel","SerrInterHelp","MeanRespHelp","SerrMeanRespLabel","SerrMeanRespHelp","DFHelp","TestTHelp","AnovaDFErrHelp","CalculatedPhat","CalculatedPhat1","CalculatedPhat2","CalculatedPhat1Label","CalculatedPhat2Label"},
{"AppQuadE","NoQUADRealRoots","EQ","EQTICK","GRAPH","GRAPHTICK","LEVEL","TEST","INC1","INC2","INCP5","INCP1","EASY","EASY1","HARD","HARD1","AppName","AnswerMenu","Incorrect","WellDone","TRY","LinearSolverInfiniteSolution","LinearSolverNoSolution","Level1","ExploreAllSols","XIntercept","YIntercept","Discriminant","Vertex","Amplitude","PhaseShift","Displacement","ChooseFunctionType"},
{"ListMat","InferenceProbLabel","IMPORT","InferenceImportTitle","InferenceImportColumnLabel","InferenceImportColumnHelp","MAKE","SortTitle","SortOrderLabel","SortOrderHelp","IndependentLabel","IndependentHelp","DependentLabel","DependentHelp","FrequencyLabel","FrequencyHelp","EnterValueHelp","MakeTitle","MakeExpressionLabel","MakeExpressionHelp","MakeVarLabel","MakeVarHelp","MakeStartLabel","MakeStartHelp","MakeStopLabel","MakeStopHelp","MakeStepLabel","MakeStepHelp","MakeColLabel","MakeColHelp","1VarOutlierLabel","1VarMin","1VarQ1","1VarMed","1VarQ3","1VarMax","1VarPercTotalLabel","1VarCumulativePercTotalLabel","InferenceImportAppHelp","1VarControlLCL","1VarControlUCL","1VarControlMean","ImportDataNotFound"},
{"Toolbox","ExportedPrograms","Calculus","Algebra","AlgebraExtract","GeoPoint","GeoLine","GeoCurve","GeoNgone","GeoTransform","GeoTest","GeoMeasure","GeoMeasurePlot","Hyperbolic","Polynomial","Probability","Trigonometry","Function","CasFunction","MATH","CONST","","","","","","Solve","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","Random","Catalog","Cata","","Create","Advanced","Expon","Arithmetic","Number","Plot","Rewrite","Diff","Integration","Limits","Transform","Prime","Divis","PolyCreate","PolyAlgebra","PolySpecial","RewriteExpLN","RewriteCos","RewriteSin","RewriteTan","RewriteTrig","DistribDensity","DistribCumulative","DistribInverse","Special","MatrixVector","MatrixBasic","Factorize"},
{"AppSpread","NAME1","StatCalcMeanXLabel","StatCalcSumXLabel","StatCalcSumX2Label","StatCalcMeanYLabel","StatCalcSumYLabel","StatCalcSumY2Label","StatCalcSumXYLabel","StatCalcNbItemLabel","StatCalcStdDevXLabel","StatCalcStdDevYLabel","StatCalcPopDevXLabel","StatCalcPopDevYLabel","StatCalcStdErrXLabel","StatCalcStdErrYLabel","StatCalcMinXLabel","StatCalcQ1XLabel","StatCalcMedXLabel","StatCalcQ3XLabel","StatCalcMaxXLabel","Spreadsheet","Cell","FormatString","FormatNameHelp","FormatName","FormatVAlign","FormatHAlign","FormatYes","FormatNo","FormatTop","FormatCenter","FormatBottom","FormatLeft","FormatRight","FormatColWidthHelp","FormatColWidth","FormatRowHeightHelp","FormatRowHeight","GotoInstr","GotoHelp2","GotoRef","StatCalcStdDev2XLabel","StatCalcPopDev2XLabel","Period","RegrIntercept","RegrCorr","RegrSampCov","RegrCoefDet","RegrPopCov","Regra","Regrb","Regrc","Regrd","Regre","RegrL","HypStatAcc","HypStatCritXbar1","HypStatCritXbar2","HypStatCp1","HypStatCp2","HypStatDeltCp1","HypStatDeltCp2","Columns","Select","Select1","ModesDigitLabel","FormatCache","SortUp","SortDown","P1TypeobBar","P1TypeobLine","P1TypeobArea","P1TypeobBarPie","P1TypeobScatter","P1SSTypeobCluster","P1SSTypeobStacked","PSSTypeobPercent100","P1SSTypeobPoints","P1SSTypeobLines","PSSTypeobPointAndLines","PSTypeHelp","PSTypeLabel","PSSubTypeHelp","PSSubTypeLabel","PSColorHelp","PSColorLabel","PSNameHelp","PSNameLabel","PSSourceHelp","PSSourceLabel","PSXAxisHelp","PSXAxisLabel","PSYAxisHelp","PSYAxisLabel","P1SSTypeobNormal","P1SSTypeobHanoi","StatCalcSSXLabel","StatCalcSSYLabel","StatCalcStdDev2YLabel","StatCalcPopDev2YLabel","HypStatCritDeltXbar1","HypStatCritDeltXbar2"},
{"AppFinan","NHelp","GroupSizeHelp","GroupSize","NLabel","PVHelp","PVLabel","PMTHelp","PMTLabel","FVHelp","FVLabel","IHelp","ILabel","PPYRHelp","PPYRLabel","CPYRHelp","CPYRLabel","Title","BegEndHelp","PayementLabel","AppName","Principal","Interest","Amortization","AMORT","Balance","BRKEVCostHelp","BRKEVCostLabel","BRKEVFixedHelp","BRKEVFixedLabel","BRKEVProfitHelp","BRKEVProfitLabel","BRKEVQuantHelp","BRKEVQuantLabel","BRKEVSalesHelp","BRKEVSalesLabel","IConvNomIHelp","IConvNomILabel","IConvEffIHelp","IConvEffILabel","IConvPPYRHelp","IConvPPYRLabel","VarsBOND","VarsBRKEV","VarsBlackScholes","VarsCashFlow","VarsDEPR","VarsIConv","","VarsTypeHelp","tTVM","tIConv","tCashFlow","tDepreciation","tBreakEven","tBond","tBlackScholes","tDateConv","OnToAbort","BondsSettDateHelp","BondsSettDateLabel","BondsMatDateHelp","BondsMatDateLabel","BondsCPNHelp","BondsCPNLabel","BondsCallHelp","BondsCallLabel","BondsYieldHelp","BondsYieldLabel","BondsPriceHelp","BondsPriceLabel","BondsAccruedLabel","BondsModDurationLabel","BondsMacaulayLabel","BondsCal360Help","BondsCal360Label","BondsAnnualHelp","BondsAnnualLabel","BSPriceHelp","BSPriceLabel","BSStrikeHelp","BSStrikeLabel","BSTTMHelp","BSTTMLabel","BSRiskFreeHelp","BSRiskFreeLabel","BSVolatilityHelp","BSVolatilityLabel","BSDividendHelp","BSDividendLabel","BSCallLabel","BSPutLabel","","DepreciationBasisHelp","DepreciationBasisLabel","DepreciationSalvHelp","DepreciationSalvLabel","DepreciationFirstHelp","DepreciationFirstLabel","DepreciationLifeHelp","DepreciationLifeLabel","DepreciationFactHelp","DepreciationFactLabel","DepreciationSLine","DepreciationSOYD","DepreciationDecBal","DepreciationDBX","DepreciationFrenchSL","DepreciationAmortFrench","DepreciationMethodHelp","DepreciationMethodLabel","","Depreciation","","DeprRemaining","DeprLeft","DDaysdate1Help","DDaysdate1Label","DDaysdate2Help","DDaysdate2Label","DDaysdeltaHelp","DDaysdeltaLabel","DDaysCal360Help","DDaysCal360Label","","PercentCalcPriceHelp","PercentCalcPriceLabel","PercentCalcCostHelp","PercentCalcCostLabel","PercentCalcMkupPCostHelp","PercentCalcMkupPCostLabel","PercentCalcMkupPPriceHelp","PercentCalcMkupPPriceLabel","","","","","PercentCalcPartPTotalHelp","PercentCalcPartPTotalLabel","PercentCalcOldHelp","PercentCalcOldLabel","PercentCalcNewHelp","PercentCalcNewLabel","PercentCalcPChangeHelp","PercentCalcPChangeLabel","PercentCalc","","","","InvestI","SafeI","CFNumb","NbCF","CF","CFIRR","CFMIRR","CFFMRR","CFTotal","CFNPV","CFNUS","CFPB","CFNFV","CFDPB","","FincanceMarginMarkup","FinanceTotalChange","","FinanceTodayLabel","","CFPYR"},
{"AppSolve","SOLVE","NumHelpLabel1","NumHelpLabel2","NumViewNoVariableErrorMesg","NumViewBadGuessErrorMesg","EnterEquationInSymbolicViewErrorMesg","NumViewSolverError","NumViewCantFindSolution","NumViewWrongVarCount","AppsSolTypeZero","AppsSolTypeConstant1","AutoscaleLHSCell","AutoscaleRHSCell","AutoscaleLHS","AutoscaleRHS","AutoscaleUsingAll","SymbHeader","CheckOnlyOne","AppName","SymbHelp"},
{"SharePlot","MENU","ZOOM","TRACE","TRACE1","DEFN","DEFN1","Setup_XRange","Setup_YRange","Setup_Axes","Setup_Labels","Setup_GridDots","NUMSTART","NumStartHelp","NUMSTEP","NumStepHelp","NumSetupNumStepPos","NUMZOOM","NumZoomHelp","NumSetupZoomGT1","Automatic","BuildYourOwn","NUMTYPE","NumTypeHelp","GotoCue","Ascending","Descending","CHOOSEZoomIn","CHOOSEZoomOut","CHOOSEZoomDec","CHOOSEZoomInt","CHOOSEZoomTrig","CHOOSEZoomUndo","Setup_AxesCue","Setup_GridDotsCue","Setup_LabelsCue","Detail","Table","CopyPlotLeft","ZoomTitle","ZoomCenter","ZoomXIn","ZoomXOut","ZoomYIn","ZoomYOut","ZoomSquare","ZoomSetFactors","ZoomTrig","ZoomFactorsTitle","ZoomFactorsX","ZoomFactorsXGT1","ZoomFactorsY","ZoomFactorsYGT1","ZoomFactorsXHelp","ZoomFactorsYHelp","ZoomRecenterHelp","ZoomRecenterLabel","ZoomBeyondLimits","FunctionGetFromPlot","Setup_Method","Setup_MethodInterval","Setup_MethodAdaptive","Setup_MethodFixedStepSegments","Setup_MethodFixedStepDots","Setup_Cursor","Setup_CursorStandard","Setup_CursorInverting","Setup_CursorBlinking","Setup_GridLines","Setup_GridLinesCue","ZoomSelectACorner","ZoomSelectOppositeCorner","FunctionSignedAreaStart","FunctionSignedAreaEnd","FunctionIntersectionXAxis","FunctionSolnRoot","FunctionSolnNoRoot","FunctionSolnExtremum","FunctionSolnNoExtremum","FunctionSolnIntersection","FunctionSolnNoIntersection","FunctionSolnSignReversal","NumZoomTitle","STOP","NoEqsChecked","XRangeNotInterval","XRangeTooNarrow","YRangeNotInterval","YRangeTooNarrow","Autoscaling","AutoscalingErr","AutoscalingNothingFound","AutoscalingSinglePoint","AutoscalingSingleX","AutoscalingSingleY","NumSetup","FunctionSignedAreaLabel","FunctionSignedAreaCalculating","AutoscaleUsingTitle","AutoscaleUsingAll","NumSortTitle","FunctionSignedAreaTitle","FunctionSolnConstNoRoot","FunctionSolnAffineNoExtremum","YRangeTooBroadForSplitscreen","SymbColorSelection","PopdownDefn","GotoXYTitle","GotoX","GotoXCue","GotoY","GotoYCue","NoFuncsChecked","SequencePlotNoneChecked","SelectionIncludesHeads","NumFontSize","NumInsertRow","NumSwapRows","CopyTo","SetupImage","Setup_ImageXRangeMinCue","Setup_ImageXRangeMaxCue","Setup_ImageYRangeMinCue","Setup_ImageYRangeMaxCue","Setup_ImageCalc","Setup_ImageCue","Setup_ImageOpacity","Setup_ImageOpacityCue","Setup_ImageOpacityBadVal","ImageXRangeNotInterval","ImageYRangeNotInterval","Table_Copy","Table_CopySelection","Table_CopyScreen","CopyScreen","Table_SelectionIncludesT","RenderingTypeCartesian","RenderingTypeFUllScreen","RenderingTypeVerticalFit","RenderingTypeHorizontalFit","RenderingTypeBestFit","RenderingTypeCentered","RenderingType","RenderingTypeHelp","Setup_ImageModeCue","Setup_ImageModeNoBackground","Setup_ImageModeNoBackgroundCue","Setup_ImageModeCentered","Setup_ImageModeCenteredCue","Setup_ImageModeStretched","Setup_ImageModeStretchedCue","Setup_ImageModeBestFit","Setup_ImageModeBestFitCue","Setup_ImageModeXYRange","Setup_ImageModeXYRangeCue","ImageCue","ImageCue_FileNotFound","FcnDefinition","FcnTransform","ImageNote_FileNotFound","ImageNote_FileNotSet","ImageCue_FileNotSet","Defn_Transpose","Defn_Simplify","Defn_Form","Setup_ImageImport","ImageImport_App","ImageImport_AppCue"},
{"AppData","ZOOM1","STATS","ErrorPrefix","ViewExperiment","JumpToTitle","JumpToTimeLabel","JumpToTimeHelp","ExperimentLengthLabel","ExperimentLabelHelp","SamplesLabel","SamplesHelp","ExportSamplingTitle","ExportSamplingStartLabel","ExportSamplingStartHelp","ExportSamplingEndLabel","ExportSamplingEndHelp","CaptureToStatsTitle","Channel1Label","Channel2Label","Channel3Label","Channel4Label","EntryLabel","EventMethodHelp","ChooseColumnHelp","EntryHelp","EventToStatTitle","TimeLabel","SensorVoltage","SensorLight","SensorMicrophone","SensorAccel","SensorForce","SensorCurrent","SensorPH","SensorDropCounter","SensorPressure","SensorEKG","SensorDistance","SensorHumidity","SensorEEG","SensorOxygen","SensorPulse","SensorConductivity","SensorSpirometer","SensorTemperature","SensorGM","SensorRain","SensorWindSpeed","SensorWindDirection","SensorPulley","SensorColor","SensorMagneticLow","SensorHumidity2P","SensorMagneticHigh","SensorDO2","SensorO2","SensorRotary","SensorMagnetic","SensorSound","SensorCO2","SensorCharge","SensorTurbidity","SensorISE","SensorSoil","SensorUser","SensorPhotogate","SensorHeat","SensorFlow","TRGR","TRGR1","EXPRT","SCOPE","SCOPE1","START","STOP","MRK","MRK1","SWAP","ADD","SETUP","CHAN","PAN","PAN1","EventWithEvent","EventAutoNumber","SensorNotConnected","StreamerNotConnected","InferenceImportAppLabel","MenuSTATS1","MenuSTATS","MenuSTATSX","MenuSTATSX1","MenuSTATSY","MenuSTATSY1","WaitingStart","WinLabel","OrSensorNotConn","SensorNotConn","ExportLeft","ExportLeft1","ExportRight","ExportRight1","ExportCount","ExportToStatistics","ExportChooseAppHelp","NotConnected","UniqueColumnError","DataColumnNotEqual","AppName"},
{"AppFunc","FCN","PlotSetup_XTick","PlotSetup_XTickPos","PlotSetup_YTick","PlotSetup_YTickPos","FunctionIndepVarX","FunctionSymbHelp","PlotSetup_XRangeMinCue","PlotSetup_XRangeMaxCue","PlotSetup_YRangeMinCue","PlotSetup_YRangeMaxCue","PlotSetup_XTickCue","PlotSetup_YTickCue","VarsPlot","VarsSymbolic","VarsNumeric","VarsResults","FcnTitle","FcnRoot","FcnIntersection","FcnSlope","FcnSignedArea","FunctionSlopeLabel","FcnExtremum","VarsModes","FunctionIntersectionTitle","FunctionSymbHeader","FcnSketch","PlotSketchCue","PlotSketchNoUnused","PlotSketchNoCandidates","PlotSketchMultipleCandidates","PlotSketchPickCandidate","ImageSelect","ImageFullScreen","ImageSize","ImageToImport","ImageImportName","ImageImportFileName","ImageImportWidth","ImageImportwidthHelp","ImageImportHeight","ImageImportHeightHelp","ImageImportAspectRatio","ImageImportAspectRatioHelp","ImageImportTitle","ImageCalculate","FcnTangent","BackgroundImage","AppName"},
{"AppLinE","AppName","RightAnswer","Level2","RESETPARAMETERS","AppNameExp"},
{"AppGeom","Symbolic","ClearAllVariables","Syntax","DebugVars","Commands","CommandsTitle","VarsAll","VarsPoints","VarsLines","VarsPolys","VarsCurves","SpreadsheetColor","SpreadsheetFill","ObjectSelectionChooseTitle","ActionSequenceTypeSelectPoint","ActionSequenceTypeSelectLine","ActionSequenceTypeSelectPointLine","ActionSequenceTypeSelectCircle","ActionSequenceTypeSelectCurve","ActionSequenceTypeSelectCurveLine","ActionSequenceTypeSelectObject","ActionSequenceSelectLocation","ActionSequenceSelectAnothPoint","ActionSequenceSelectPointOrSegment","ActionSequencePolygon","ActionSequenceEnterAngle","ActionSequenceEnterScale","ActionSequenceNbSides","ActionSequenceSelectFocus","ActionSequenceEnterExpression","ActionSequenceExpressionInX","ActionSequenceParam","ActionSequenceSelectPointOnObject","ActionSequenceSelectPointOrTriange","ActionSequenceRandom","Plot","PixelSize","PixelSizeHelp","PlotSetupLongTextScrollHelp","PlotSetupLongTextScroll","CHECKALL","UNCHECKALL","MesureName","MesureDefault","MesureCastesian","MesureMesure","MesureTests","SliderMoveCursor","AnimFixed","AnimBackAndForth","AnimLoop","AnimTypeHelp","AnimType","AnimStepsPersHelp","AnimStepsPers","AnimPauseHelp","AnimPause","AnimMinHelp","AnimMin","AnimMaxHelp","AnimMax","AnimPosHelp","AnimPos","AnimStepHelp","AnimStep","AnimEdit","TracedTick","Traced","TraceClear","FillColorTick","FillColor","AnimateTick","Animate","ViewLabel","OptionMenu","OptionsPointStyle","Hide","HideLegend","ShowLegend","ODEFunctionHelp","ODEVar1Help","ODEVar2Help","ODESteps","ODEXStepsHelp","ODEeqLabel","ODEYStepsHelp","","","ODEVars","Geometry"},
{"AppSeq","NumSetupNumStartPos","NumSetupNumStepPos","NumSetupZoomGT1","Stairstep","Cobweb","PlotSetup_NRange","SEQPLOT","PlotSetup_NRangeMinCue","PlotSetup_NRangeMinNPI","PlotSetup_NRangeMaxCue","PlotSetup_NRangeMaxNPI","PlotSetup_PlotTypeCue","SeqAppIndepVarN","Symb1Header","Symb2Header","Symb3Header","Plot_NRangeNotInterval","OOD","SeqeunceEnterStartN","EnterValue","AppName","ForwardDefine","OptionUN","OptionUNP1","HelpOptions","HelpStart"},
{"AppLinS","AppName","Title","X","Y","Z","Yequal","2x2Enable","3x3Disable","2x2Disable","3x3Enable"},
{"AppTriS","AppName","SideA","SideB","SideC","T","U","V","RECT","TriangleNotEnoughDATA","TriangleADDSide","NoSolution","SolutionFound","InvalidAngle","InvalidAngleDeg","HelpLabel","HelpLabel2","RECT2","ALT","ALPHA","BETA","GAMMA","SIDEA","SIDEB","SIDEC","InfiniteSolutions"},
{"AppStat2","AppName","EnterIndependent","EnterDependent","EnterFrequency","LinearFit","LogarithmicFit","ExponentialFit","PowerFit","QudraticFit","CubicFit","QuarticFit","NthPolynomialFit","LogisticFit","ExponentFit","InverseFit","TrigonometricFit","UserDefinedFit","MedMedFit","StatPlotSetupMarkChooseHelp","StatPlotConnectHelp","StatPlotConnectLabel","FIT","FIT1","ChooseType","FitType","FitLabel","Stat2VarSymbHeader1","MarkColor"},
{"AppAdvG","InvalidSyntax","SymbHeader","SymbHelp","TracingTitle","TracingOff","TracingInside","TracingBoundary","SymbNotOpenSen","SymbUnsupportedOpIs","SymbUnsupportedOp","SymbUnsupportedElIs","SymbUnsupportedEl","SymbComplexesUnsupported","SymbListsUnsupported","SymbMatricesUnsupported","PlotNoneChecked","TracingPointsOfInterest","TracingXIntercepts","TracingYIntercepts","TracingInflections","TracingHExtrema","TracingVExtrema","TracingIntersections","TracingIntersectionsWith","NumIndepVarX","NumIndepVarY","NumBYOSat","NumBYOUnsat","NumSetupXStart","NumSetupYStart","NumSetupXStep","NumSetupYStep","NumSetupXZoom","NumSetupYZoom","NumSetupXStartHelp","NumSetupYStartHelp","NumSetupXStepHelp","NumSetupYStepHelp","NumSetupXZoomHelp","NumSetupYZoomHelp","NumSetupXStepPos","NumSetupYStepPos","NumSetupXZoomGT1","NumSetupYZoomGT1","NumBYOTrue","NumBYOFalse","TracingIntersectionsOfItem","TracingIntersectionsOf","TracingPointsOfInterestTitle","NumIntersectionDialogTitle","NumIntersectionDialogLine1","NumIntersectionDialogLine2","NumIntersectionDialogHelp1","NumIntersectionDialogHelp2","NumIntersectionDialogError","NumXEdgeDefn","NumYEdgeDefn","NumXInterDefn","NumYInterDefn","NumHExtDefn","NumVExtDefn","NumInflDefn","NumIntersectionDefn","NumManyDefn","TracingSelection","PlotGallery","NumHExtXYDefn","NumVExtXYDefn","NumInflXYDefn","NumIntersectionXYDefn","AppName"},
{"AppTrigE","Cos","Sin","Degree","Radian","Drift","Extr","PIBy9","PIBy6","PIBy4","Degree20","Degree30","Degree45","WrongAnswer","Level5","Level3","Level4","AppName"},
{"Notes","NotepadTitle","NEW","FORMAT","CenterAlign","LeftAlign","RightAlign","Align","Font","Style","NotepadEnterName","NoteWithSameNameExists","NewNote","ModeBGColorLabel","ModeFGColorLabel","AreYouSureClearAllText","AreYouSureYouWantToDeleteThisNote","EnterNewNoteName","TITLESaveNoteAs","ExceededTheMaxCharsLimit","RENAME","TITLERenameNoteAs","Enternewname"},
{"Error","ERNone","ERInexact","ERUnderflow","EROverflow","ERDivZ","ERZDivZ","ERInfMulZero","ERInfDivInf","ERSqrNeg","ERLnZero","ERLnNeg","ERNegFact","ERATrigSup1","ER1PowInf","ERNegPowInf","ERInfPow0","ERInfPowFrac","ERxPowFractNeg","ERooBounds","ERExponent","ERTwoComma","ERNoDigits","ERSyntax","ERInvalidPPYR","ERInvalidInput","ERInvalidI","ERNoSol","ERMainyNoSol","ERMainySol","ERInvalidN","ERUserBreak","ERInfiniteResult","ERInsufisantData","ERNoPayback","ERIRR0","ERUniquePosIRRNotFound","ERStack","ERParenthesis","ERInsufisantMemory","ERZeroFinderNoSolutionFound","ERZeroFinderBadGuesses","ERZeroFinderExtemumFound","ERZeroFinderConstantFunction","ERZeroFinderPoleFound","ERZeroFinderSolInBetween","ERBadArguementCount","ERVariables","ERBadArguementType","ERUndefinedNativeCall","ERCircularReference","ERUserError","ERUnmatchControlWord","ERInvalidPC","ERIllegalIndirection","ERNoInput","ERInvalidObject","ERUndefinedResult","ERInvalidDimention","ERCanNotDisplay","ERProbabilityRange","ERProbabilityMustBe1","ERWeightIsLT0","ERNotEnoughDefinitions","ERStatDataNotEqual","ERInvalidEq","ERInconsistentUnits","ERBreakContinueKill","ERDisabledFunction","ERRecursionLimit","","ERNoPlotViewForThisSetting"},
{"Parser","ZoomBox","ZoomIn","ZoomOut","ZoomAutoscale","ZoomDecimal","ZoomInteger","ZoomUnzoom","INPUThelp","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","DoYouWantToCreateVar","SSRegrSlope","GeomLineSegment","GeomLineRay","GeomLineLine","GeomLineOtherAngleBisect","GeomLineOtherPerpBisect","GeomLineOtherParallel","GeomLineOtherPerpendicular","GeomLineOtherTangent","GeomLineOtherMedian","GeomLineOtherAltitude","GeomPolygonTriangle","GeomPolygonIsoscTri","GeomPolygonRightTri","GeomPolygonQuadrilateral","GeomPolygonSpecialSquare","GeomPolygonSpecialParallelogram","GeomCurveCircle","GeomCurveEllipse","GeomCurveHyperbola","GeomCurveParabola","GeomCurveConic","GeomCurveSpecialCircumcircle","GeomCurveSpecialIncircle","GeomCurveSpecialExcircle","GeomCurveSpecialLocus","GeomTransformTranslation","GeomTransformReflection","GeomTransformDilation","GeomTransformSimilarity","GeomTransformRotation","GeomTransformOtherProjection","GeomTransformOtherInversion","GeomTransformOtherReciprocation","GeomPointPoint","GeomPointPointOn","GeomPointMidpoint","GeomPointIntersection","GeomPointRandom","GeomPointOtherCenter","GeomPointOtherIntersections","TBPercentage","TBFnRoot","TBModulus","TBArg","TBConj","TBIm","TBRe","TBSign","TBBinomial","TBChi2","TBFisher","TBNormal","TBPoisson","TBStudent","TBConcat","TBSigList","TBProdList","TBDeltaList","TBMakeList","TBPos","TBReverse","TBSize","TBSort","TBCross","TBDet","TBDot","TBTrn","TBColNorm","TBNorm","TBL1Norm","TBL2Norm","TBMaxNorm","TBCond","TBPivot","TBRank","TBRowNorm","TBSpecNorm","TBSpecRad","TBIdenMat","TBTrace","TBJordan","TBMakemat","TBmkisom","TBVandermonde","TBCholesky","TBDiag","TBEigenval","TBEigenvect","TBHessenberg","TBHilbert","TBIsmith","TBfft","TBifft","TBCeiling","TBFloor","TBFrac","TBInt","TBMant","TBRound","TBTruncate","TBXpon","TBFactorial","TBCombination","TBPerm","TBRandNorm","TBRandomNum","TBRandomInt","TBRandomSeed","TBRandom","TBCollect","TBExpand","TBFactor","TBPartfrac","TBSubst","TBtExpand","TBDiff","TBIntegrate","TBLimit","TBSeries","TBSum","TBCurl","TBDiverg","TBGrad","TBHessian","TBInvLap","TBLaplace","TBdivpc","TBsumriemann","TBtaylor","TBidivis","TBifactor","TBifactors","TBigcd","TBlcm","TBpowmod","TBEuler","TBisprime","TBithPrime","TBnextprime","TBprevprime","TBdenom","TBichinrem","TBiquo","TBirem","TBnumer","TBplotcontour","TBplotfield","TBplotfunc","TBplotimplicit","TBplotparam","TBplotpolar","TBplotseq","TBplotlist","TBplotode","TBcSolve","TBcZeros","TBdeSolve","TBlinsolve","TBnsolve","TBodesolve","TBsolve","TBzeros","TBcoeff","TBproot","TBfcoeff","TBsturmab","TBpcoeff","TBpoly2Symb","TBsymb2Poly","TBcontent","TBdegree","TBfactor_xn","TBcyclotomic","TBgbasis","TBgreduce","TBhermite","TBlagrange","TBlaguerre","TBLegendre","TBtcheby1","TBtcheby2","TBacost2asin","TBleftside","TBrightside","TBacos2atan","TBcos2sintan","TBexp2pow","TBexp2trig","TBexpexpand","TBpow2expand","TBasin2acos","TBasin2atan","TBsin2costan","TBatan2acos","TBatan2asin","TBhalftan","TBtan2sincos","TBatrig2ln","TBtCollect","TBtlin","TBtrig2exp","TBtrigcos","TBtrigexpand","TBtrigsin","TBtrigtan","TBIbpdv","TBibpu","TBpreval","TBisopolygon","TBrhombus","TBiscollinear","TBisconcyclic","TBisconjugate","TBiselement","TBisequilateral","TBisisosceles","TBisparallel","TBisperpendicular","TBisparallelogram","TBisrectangle","TBmeasabscissa","TBmeasaffix","TBmeasangle","TBmeasarclen","TBmeascoord","TBmeasdistance","TBmeasequation","TBpolarcoords","TBmeasperimeter","TBmeasradius","TBmeasordinate","TBmeasparameq","TBIntersect","TBDifference","TBGeometric","TBUnion","TBCFactor","TBSlider"},
{"AppStat1","1VarHistogram","1VarBoxWhisker","1VarLine","1VarNPP","1VarPie","1VarPareto","1VarBar","PlotSetup_Hwidth","PlotSetup_HwidthCue","PlotSetup_HRange","PlotSetup_MinHRangeCue","PlotSetup_MaxHRangeCue","PlotHelp","PlotType","PlotSetup_HWidthPos","1VarSymb1Header","1VarDot","1VarStemLeaf","1VarControl","PlotOptionHelp","1VarNoOutliers","1VarShowOutliers","1VarOption","1VarControlIndiv","1VarControlMR","AppName","CalcMeanXHelp","CalcSumXHelp","CalcSumX2Help","CalcMeanYHelp","CalcSumYHelp","CalcSumY2Help","CalcSumXYHelp","CalcSampCovLabel","CalcSampCovHelp","CalcPopCovLabel","CalcPopCovHelp","CalcNbItemHelp","CalcStdDevXHelp","CalcStdDevYHelp","CalcPopDevXHelp","CalcPopDevYHelp","CalcStdErrXHelp","CalcStdErrYHelp","CalcMinXHelp","CalcQ1XHelp","CalcMedXHelp","CalcQ3XHelp","CalcMaxXHelp","CalcMinYHelp","CalcSSXHelp","CalcSSYHelp","StemLeafSingle","StemLeafSplit"},
{"AppPolar","PlotSetup_ThetaRange","PlotSetup_ThetaStep","PlotSetup_ThetaStepPos","PlotSetup_ThetaRangeMinCue","PlotSetup_ThetaRangeMaxCue","PlotSetup_ThetaStepCue","IndepVar","Plot_ThetaRangeNotInterval","SymbHeader","AppName"},
{"AppParam","PlotSetup_TRange","PlotSetup_TStep","PlotSetup_TStepPos","PlotSetup_TRangeMinCue","PlotSetup_TRangeMaxCue","PlotSetup_TStepCue","IndepVar","Plot_TRangeNotInterval","Symb1Header","Symb2Header","AppName"},
{"App3D","PlotSetupSurface_GriddedTwoSided","PlotSetup_ZRangeMinCue","PlotSetup_ZRangeMaxCue","SymbHeader","AppName","SymbCue","PlotSetup_ZRange","PlotSetup_XRangeMinCue","PlotSetup_XRangeMaxCue","PlotSetup_YRangeMinCue","PlotSetup_YRangeMaxCue","PlotSetup_Grid","PlotSetup_Gridx","PlotSetup_GridXCue","PlotSetup_GridYCue","PlotSetup_BoxSides","PlotSetup_BoxSidesCue","PlotSetup_GridErr","Plot_ZRangeNotInterval","Plot_ZRangeTooNarrow","ZoomZIn","ZoomZOut","ZoomSquareXY","ZoomFactorsZGT1","ZoomFactorsXCue","ZoomFactorsYCue","ZoomFactorsZCue","ZoomFactorsZ","PlotSetup_PoseXAxis","PlotSetup_PoseYAxis","PlotSetup_PoseZAxis","PlotSetup_PoseTurn","PlotSetup_PoseXAxisCue","PlotSetup_PoseYAxisCue","PlotSetup_PoseZAxisCue","PlotSetup_PoseTurnCue","Plot_PoseAxisErr","PlotSetup_BoxScale","PlotSetup_BoxScaleCue","PlotSetup_BoxScaleErr","PlotSetup_BoxFrame","PlotSetup_BoxFrameCue","PlotSetup_Surface","PlotSetupSurface_TwoSided","PlotSetupSurface_Checkerboard","PlotSetupSurface_Elevation","GotoZCue","PlotSetup_BoxXSideColorCue","PlotSetup_BoxYSideColorCue","PlotSetup_BoxZSideColorCue","PlotSetup_SteppingErr","PlotSetup_CheckerXCue","PlotSetup_CheckerYCue","PlotSetup_ZTick","PlotSetup_XTickCue","PlotSetup_YTickCue","PlotSetup_ZTickCue","PlotSetup_ZTickPos","PlotSetup_Marks_None","PlotSetup_Marks_Rear","PlotSetup_Marks_FrontAndRear","SurfaceColoring","PlotSetup_BoxAxesColorCue","PlotSetup_BoxLinesColorCue","PlotSetup_BoxDotsColorCue","PlotSetup_BoxFrameColorCue","PlotSetup_BoxAxesCue","PlotSetup_BoxLinesCue","PlotSetup_BoxDotsCue","PlotSetup_SurfaceCue","PlotSetup_Marks_Zmin","PlotSetup_KeyAxes","PlotSetup_KeyAxesCue","PlotSetup_KeyXAxisColorCue","PlotSetup_KeyYAxisColorCue","PlotSetup_KeyZAxisColorCue","PlotSetupSurface_Slope","PlotSetup_GriddingXCue","PlotSetup_GriddingYCue","PlotSetup_BoxLines","PlotSetup_BoxDots","PlotSetup_BoxAxes","PlotSetup_Checker","PlotSetup_LabelsCue","Spin","AutoscalingSingleZ"},
{"Units","Unit_m","Unit_cm","Unit_mm","Unit_Km","Unit_au","Unit_lyr","Unit_pc","Unit_Angstrom","Unit_chain","Unit_fath","Unit_fermi","Unit_yd","Unit_ft","Unit_ftUS","Unit_inch","Unit_mile","Unit_nmi","Unit_miUS","Unit_mil","Unit_rod","Unit_m2","Unit_Km2","Unit_cm2","Unit_ha","Unit_a","Unit_acre","Unit_b","Unit_yd2","Unit_ft2","Unit_inch2","Unit_mile2","Unit_miUS2","Unit_m3","Unit_cm3","Unit_l","Unit_ml","Unit_st","Unit_yd3","Unit_ft3","Unit_inch3","Unit_bbl","Unit_bu","Unit_buUS","Unit_cu","Unit_fbm","Unit_ozfl","Unit_ozUK","Unit_tbsp","Unit_tsp","Unit_qt","Unit_liqpt","Unit_ptUK","Unit_pk","Unit_galUS","Unit_galUK","Unit_s","Unit_mn","Unit_h","Unit_d","Unit_yr","Unit_Hz","Unit_mps","Unit_cmps","Unit_ftps","Unit_kph","Unit_mph","Unit_knot","Unit_radps","Unit_trpmn","Unit_trps","Unit_Kg","Unit_g","Unit_grain","Unit_lb","Unit_lbt","Unit_oz","Unit_ozt","Unit_slug","Unit_tonUK","Unit_tonUS","Unit_u","Unit_t","Unit_ct","Unit_mps2","Unit_Gal","Unit_radps2","Unit_Kgmps2","Unit_N","Unit_dyn","Unit_kip","Unit_gf","Unit_lbf","Unit_pdl","Unit_Kgm2ps2","Unit_J","Unit_Wh","Unit_KWh","Unit_Kcal","Unit_cal","Unit_eV","Unit_MeV","Unit_Btu","Unit_erg","Unit_therm","Unit_toe","Unit_tec","Unit_lep","Unit_bblep","Unit_boe","Unit_cf","Unit_Kgm2ps3","Unit_W","Unit_MW","Unit_hp","Unit_Kgpmps2","Unit_Pa","Unit_bar","Unit_atm","Unit_psi","Unit_torr","Unit_mmHg","Unit_inHg","Unit_inH2O","Unit_K","Unit_Rankine","Unit_0C","Unit_0F","Unit_A","Unit_V","Unit_C","Unit_Ohm","Unit_F","Unit_Fdy","Unit_Wb","Unit_H","Unit_mho","Unit_S","Unit_T","Unit_Ah","Unit_cd","Unit_flam","Unit_rad","Unit_deg","Unit_grad","Unit_gon","Unit_arcmin","Unit_arcs","Unit_tr","Unit_m2ps","Unit_P","Unit_St","Unit_Bq","Unit_Ci","Unit_Gy","Unit_rd","Unit_rem","Unit_Sv","Unit_R","Unit_mol","Unit_ftlbfps","Unit_ftlbf","Unit_mileph","Unit_ftps2","Unit_grav","Unitm_Y","Unitm_Z","Unitm_E","Unitm_P","Unitm_T","Unitm_G","Unitm_M","Unitm_K","Unitm_H","Unitm_D","Unitm_d","Unitm_c","Unitm_m","Unitm_u","Unitm_n","Unitm_p","Unitm_f","Unitm_a","Unitm_z","Unitm_y","Constant_NA","Constant_k","Constant_Vm","Constant_R","Constant_StdT","Constant_StdP","Constant_Sigma","Constant_c","Constant_e0","Constant_m0","Constant_g","Constant_G","Constant_h","Constant_hBar","Constant_q","Constant_me","Constant_qme","Constant_mp","Constant_mpme","Constant_alpha","Constant_phi","Constant_F","Constant_Rinf","Constant_a0","Constant_mB","Constant_mN","Constant_l0","Constant_f0","Constant_lc","UnitsPrefix","UnitsLength","UnitsArea","UnitsVolume","UnitsTime","UnitsSpeed","UnitsMass","UnitsAcceleration","UnitsForce","UnitsEnergy","UnitsPower","UnitsPressure","UnitsTemperature","UnitsElectricity","UnitsLight","UnitsAngle","UnitsViscosity","UnitsRadiation","Math","Constants","Chemist","Quantum","Unit1","Unit11","Unit2","Unit21","TOOLS"},
{"ExamMode","Test"},
{"ShareSymb","Empty"},
{"DefBase","Test"},
{"ShareNum","Test"},
{"CasSet","Test"},
{"ZoomImage","Test"},
{"EmptyEnd","Test"}};
 lg:={"English","中文 (简体)","Français","Deutsch","Español","Nederlands","Português","日本語"};  // Language list
 Nmb:="STRINGFROMID_"+lg(Language)+".txt";                                                       // File name
 DelAFiles(Nmb);
 AFilesB(Nmb,0):={255,254};
 k:=MAX(MAKELIST(DIM(li(I,1))+MAX(DIM(tail(li(I)))),I,1,SIZE(li)))+1;   // Maximum length of any "group_ID" string
 FOR j FROM 1 TO SIZE(li) DO                             // For each group
   group:=li(j,1);                                       //   get group name
   id_list:=sort(UNION(tail(li(j))));                    //   get sorted list of IDs for this group, without duplicates
   if id_list(1)=="" THEN id_list:=tail(id_list); END;   //   remove empty string ID if any
   FOR id FROM 1 to SIZE(id_list) DO                     //   for each ID within a group
     str:= group+"_"+id_list(id);                        //     build "group_id" string
     Tx:=REPLACE(str,k+3,"")+STRINGFROMID(str)+"\r\n";   //     pad "group_id" string with spaces up to k+2 characters and add the localized string
     LOCAL y,Nvo={};
     FOR y:=1 TO DIM(Tx) DO
       Nvo(0):=Tx(y);
       Nvo(0):=BITSR(Tx(y),8)
     AFilesB(Nmb,AFilesB(Nmb)):=Nvo;                     //     Store Unicode text
 lg(Language)+": Done!"
And the txt files extracted from the current beta version:
1 English
2 中文 (简体)
3 Français
4 Deutsch
5 Español
6 Nerderlands
7 Português
8 日本語
09-20-2018, 06:15 AM
RE: STRINGFROMID and gradians
Nice work!
Cyrille
09-20-2018, 06:38 AM (This post was last modified: 09-20-2018 08:28 AM by StephenG1CMZ.)
Its interesting that the English text has a few entries relating to Program_GOTOLinenumber, a feature a few people would like to see (although perhaps that is just for debugging, rather than a PPL Statement).
And the English has a couple of Chinee/Japanase entries - perhaps the language selection screen?
Stephen Lewkowicz (G1CMZ)
09-20-2018, 05:52 PM
(09-20-2018 06:38 AM)StephenG1CMZ Wrote:  Its interesting that the English text has a few entries relating to Program_GOTOLinenumber, a feature a few people would like to see (although perhaps that is just for debugging, rather than a PPL Statement).
I wouldn't mind an HPPL GOTO statement! Even C has GOTO and it would make translating programs to HPPL easier in some cases.
Tom "The Programming Heretic" Lake
Tom L
Cui bono?
09-20-2018, 05:58 PM
Let our program be:
Drum the tom-tom and throw the heretic into the lake!
as
there are more important things to fix and add than GOTOLinenumber
VPN
User(s) browsing this thread:
