HP48 Sparcom Calculus Pac Owner's Manual
09-19-2018, 07:24 PM
Finally got around to scanning the Owner's Manual for the Sparcom Calculus Pac which was a plug-in ROM for the HP48SX. Please do with it whatever you wish, including adding it to any documentation collections.
[Image: SCP-cover.jpg]
http://holyjoe.net/hp/Sparcom_Calculus_Pac.pdf
34MB, 222 pages, searchable PDF. The original was 8.5 inches high by 5.5 inches wide, spiral bound. The blank pages in the PDF were blank in the manual.
<0|ɸ|0>
-Joe-
09-20-2018, 04:40 AM
RE: HP48 Sparcom Calculus Pac Owner's Manual
Great scanning job, thanks much for sharing it.
ÁM
09-20-2018, 06:11 AM
Graet work!
is there somewhere the image of the card to use in an emulator?
Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50
09-20-2018, 07:39 PM
Thanks very much for the scan. I have both the H.O.-48SX and 48GX.
I don’t have the Sparcom module. Is there a resource anywhere that lists all the programs on the module along with the source code?
Denny Tuckerman
10-03-2018, 04:11 PM
Fr> Dumping carte ROM Math Pro pour HP-48SX/G+/GX
https://tiplanet.org/forum/viewtopic.php?f=55&t=10626
Please can scan other manuals of the hp48-ROMS applications, Mathpro, Spice, etc.
10-04-2018, 01:35 AM
(09-19-2018 07:24 PM)Joe Horn Wrote:  Finally got around to scanning the Owner's Manual for the Sparcom Calculus Pac which was a plug-in ROM for the HP48SX. [...]
Many thanks, Joe! I vaguely remember beta-testing that one.
10-04-2018, 02:21 AM (This post was last modified: 10-04-2018 02:45 AM by Jlouis.)
Can't thanks enough Joe Horn for scanning the manual and compsystem for point out where to download the file.
Edit: Attention - the manual does not relate to the dumped Rom link.
One is calculus PAC (manual)
The other is math pro (Rom dump)
10-04-2018, 03:46 AM
FYI, this ended up on the HHC 2018 USB drive. Thanks Joe!
10-05-2018, 06:31 PM
Take a look at https://groups.google.com/forum/#!topic/...cuzRtk9fJE and you will find a link to https://www.4shared.com/postDownload/c8A...bspdf.html.
Then put a false email (if you want) to access the zip file. Some images of Sparcom cards.
10-06-2018, 01:55 AM
(10-05-2018 06:31 PM)Dimitri Wrote:  Hello,
WOW
Thanks Dimitri!
The original post is from 2009!!
and the file is still there!!
Ok, busy weekend! SmileSmile
10-11-2018, 10:07 PM
Thanks for sharing Dmitri.
NOTE/CAUTION: The linked 4shared.com page(s) launch remote malware injection (fake technician and others) so be sure you are protected before accessing this page. That said, the file was retrieved successfully.
09-09-2020, 06:02 PM
Necro Threading this topic as I picked up a broken for 48SX just to take apart and successfully fixed the ribbon connection. Its slow but for someone who only occasionally graphs a scattergram to see if the ole eqn fits, it does its job.
The Sparcom cards look like it might add some utility. That said.
I checked the 4shared site and *yikes* that lit up the system warnings like a pinball machine. Needless to say the operation was aborted. Does anyone happen to have saved the file? It might be good to have it on the MoHPC flash drive - I checked and didn't see it there.
Or please pop a less exciting link up. Smile
Thanks!
Bill
