Missing solution for exponential equation
10-01-2018, 11:45 PM
(This post was last modified: 10-01-2018 11:51 PM by rushfan.)
The peak response of an underdamped second order system is:
Mpt = 1 + e^((-z*pi)/sqrt(1-z^2)) Where Mpt is real. For Mpt = 5, the command: solve( 5 = 1 + e^((-z*pi)/sqrt(1-z^2)) ,z) Returns: ![]() Which is only the negative result. The same happens in the Solve app, I only get the negative result. The same code in matlab: clc; syms z; eqn = 5 == 1+ exp((-z*pi)/sqrt(1-z^2)); vpa(solve(eqn,z)) produces: ans = 0.40371275194342068038575605143555 -0.40371275194342068038575605143555 |
10-02-2018, 01:02 AM
RE: Missing solution for exponential equation
Try both answers from matlab in your expression. :-)
Prime G2, 15C CE |
10-02-2018, 03:02 AM
What is inside e^(...) must be positive, so (-z*pi)/sqrt(1-z^2) > 0, this imply z < 0
Matlab positive z is a mistake. (Probably just return solved quadratic roots) |
10-02-2018, 05:36 AM
Xcas 1, Matlab 0 :-)
