CAS SETTINGS: full reserved variables
10-08-2018, 09:46 PM
(This post was last modified: 04-19-2021 07:48 PM by compsystems.)
Hi, other variables that are not documented or do not appear in the hp-prime catalog. Please hpteam to include them in future updates
list of internal variables: {approx_mode, complex_variables, complex_mode, all_trig_solutions, angle_radian, with_sqrt, increasing_power, bisection_solver, newtonj_solver}, etc. bisection_solver:="hello"; // do not allow, when trying to store a invalid object on the reserved variables, it should show an error message approx_mode:=1; approx_mode:="hello"; // do not allow complex_variables:=0; complex_mode:=0; example of use of the flags (internal variables), to show in the history different results or forms, for this reason it is important to include (next firmware) these internal variables that in some cases act as commands xcas PHP Code: with_sqrt(0):; factor((5*s^2+32*s+45)/(s^3+6*s^2+9*s)) |
10-08-2018, 11:17 PM
RE: reserved variables
If such a list were made, it would be very helpful to also distinguish between the ones which can only be used in CAS mode, as well as the built-in named constants (e.g. title which always seems to be equal to 15).
<0|ɸ|0> -Joe- |
