solución
10-09-2018, 10:34 PM (This post was last modified: 10-10-2018 12:01 AM by Gene.)
solución
hola amigos alguien me podría decir como arreglo, el problema es que estaba actualizando mi calculadora y de pronto se apago y no prende mas que puedo hacer o si conocen algún técnico en lima me pueden comentar por favor.
Moderator Note: Please use English in the forums. Google translate renders the above as...
"hello friends someone could tell me how to fix, the problem is that I was updating my calculator and suddenly it went off and it does not turn on any more I can do or if you know any technician in Lima you can comment me please."
10-10-2018, 10:17 PM (This post was last modified: 10-10-2018 10:18 PM by sasa.)
RE: solución
(10-09-2018 10:34 PM)dolfergr Wrote:  "hello friends someone could tell me how to fix, the problem is that I was updating my calculator and suddenly it went off and it does not turn on any more I can do or if you know any technician in Lima you can comment me please."
These info may help:
http://www.hpmuseum.org/forum/thread-166.html
https://h30434.www3.hp.com/t5/Calculator...-p/5637751
