string to variable
04-24-2014, 01:38 AM
string to variable
in a program can you convert a string into a variable?
04-24-2014, 01:40 AM
RE: string to variable
Sure, if you initialize it to some value you can.
This creates a CAS variable named MyVar with an initial value of 0. Graph 3D | QPI | SolveSys |
04-24-2014, 02:06 AM
Thank you very much
04-30-2014, 09:57 AM
An other way for this (in a CAS-Program) is
#("ABC_"):=4711; This creates the global CAS-Variable ABC_ with value 4711. Of course this is also possible with a variable which contains a string: #CDE_:=4712; creates the global CAS-Variable ABC_ with value 4712, if the variable CDE_ has the value "ABC_". OldHPUser |
