go42s update
10-17-2018, 05:25 PM (This post was last modified: 10-18-2018 05:06 PM by Gerald H.)
go42s update
On a Samsung Galaxy state stores as .r17bii file, .r42s files can't be recalled.
Anyone have the same problem?
10-20-2018, 05:25 AM
RE: go42s update
New update, 1.4.2, fixes some bug(s), still saves state as .r17bii & refuses to load .r42s.
10-20-2018, 05:44 AM
RE: go42s update
I confirm that the new version of go42s saves RAM files with .r17bii extension.
I don't have any previous .r42s file so I can't test the loading of these ones.
Did you report the issue to the go42s author?
I had an issue with the update 1.4.0 crashing on my tablet, I reported the issue and 1.4.1 fixing this issue was released within a couple of days.
Also have you tried to rename your .r42s files to .r17bii and load them?
10-20-2018, 11:57 AM
RE: go42s update
I have reported this on google play:
https://play.google.com/store/apps/detai...p42s&hl=en
Where else is there to report?
Renaming to .r17bii works for loading.
10-20-2018, 03:04 PM
RE: go42s update
I've just received v1.4.3 fixing the saved files extension.
10-20-2018, 03:57 PM
RE: go42s update
Thank you, Didier, 1.4.3 seems to work correctly now.
