Old computers did it better!
10-18-2018, 12:23 AM
10-18-2018, 03:42 AM
RE: Old computers did it better!
I wholeheartedly agree, but on the point of the superior Commodore 64 documentation, that video cheats a little. It starts by showing the manual, which was indeed included, but then it sneakily cuts to the Programmer's Reference Guide (1:11), which was essential if you really wanted to get into programming the thing... and was sold separately.
/geek out ![]() |
10-18-2018, 05:05 AM
Funnily enough, many moons ago I had a job in Commodore service centre and the number of those C64 machines that I repaired was alarming. In the 5.5 years I spent in that job, I must have repaired literally thousands of C64, C128 and Amiga machines and they weren't all as easy to repair as the video makes out. In later production runs they did away with DIL IC sockets and the ICs were soldered directly onto the boards. Then they started using surface mounted devices...
10-18-2018, 05:29 AM
What were the most common repairs? I seem to recall that the SID and CIA chips were particularly vulnerable, something having to do with the CPU buses being directly exposed on the rear connector or something. Mine mostly stayed put and didn't get things plugged and unplugged very often (except for joysticks, anyway), and that may have helped, or maybe I was just lucky! I did have wall-to-wall carpeting, so static discharge was definitely a risk.
10-18-2018, 06:31 AM
I don't remember too many problems with the CIA chips, strangely enough. The SID was definitely a weak point in those machines, as was the VIC.
In the Amiga 500 and 600, it was indeed almost always the chips that drove the I/O (8520? This was 30 years ago and I've slept since then) or the floppy drive that needed changing. Close runners up were a leaky NiCd battery in the A501 memory extension and a fault in the power supply where the 470K resistor between the +400V hot side and the base of the switching transistor that just became an open circuit so the oscillator never started => no power. The Atari ST family of machines (we were also an Atari centre) were generally more reliable except that the ROM chips often needed re-seating in their sockets and their floppy drives were a bit of a nightmare. Worst thing about them was the fact that Atari kept on changing the design of them so there was a good chance that a new floppy drive ordered from them would not fit in the case of the machine you had with its guts open on your workbench. The STE machines often had the same power supply fault as the Amigas but by far the most common fault was hilarious. The STF had an MMU chip and another logic chip that they called the GLUE chip. The STE combined the two into a single 144-pin SMD. The glue that they would use to stick it to the motherboard before passing it through the solder wave would corrode the copper tracks below the chip. I spent a couple of days trying to figure out the cause of the first machine I saw to exhibit the problem! |
10-18-2018, 06:05 PM
Gosh, I still have an old Atari 520ST (without ROMS, boot off floppy). I wonder if it still works....
10-18-2018, 06:13 PM
RE: Old computers did it better! | |||
10-18-2018, 09:02 PM
nothing wrong with surface mount.
Old calculators did it better too... |
10-19-2018, 03:31 AM
Surface-mount brought a lot of improvements. Breadboardability and ease of modification and probing and, in the cases of any failure, repair, are unfortunately not among them.
Things I miss about the computers of yesteryear:
Does the mere fact that something can be done mean it should be done? Moving on from a GUI on a 1MHz 8-bit computer (GEOS on C64), take hi-res video for example. When I go to Fry's, immediately as I enter, I'm greeted by a big-screen hi-def TV showing performers on stage, and you can even see their nose hair, which I'd rather not see. Some people may have a legitimate use for downloading a feature-length movie in a few minutes max. I and my family don't. Our DSL is 3Mbps download, fast enough for all of us to be watching YouTube videos at the same time. Gas pumps and ATMs have large color monitors now so they can advertise to you; but I wish they'd go back to just a basic monochrome text display that can be easily read when the sun is shining on it, and no sound other than beeps. BTW, I absolutely loathe touch screens—the grime, the parallax, the lack of precision—and the ones at our bank's ATMs sometimes do not want to respond to my fingers anyway. http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, http://wilsonminesco.com/links.html ) |
10-19-2018, 06:07 PM
(This post was last modified: 10-19-2018 06:40 PM by Albert Chan.)
(10-19-2018 03:31 AM)Garth Wilson Wrote: BTW, I absolutely loathe touch screens—the grime, the parallax, the lack of precision spitting to the screen help ... ![]() https://www.consumerreports.org/cro/news.../index.htm |
10-19-2018, 06:39 PM
On the subject of Commodore, if you C64 fans haven't built a Pi1541, you're missing out! It's a cycle-accurate 1541 emulator running on a Raspberry Pi and connected to your C64/C128/Vic-20/etc. You can fit mountains of disk images on a big microSD card.
https://cbm-pi1541.firebaseapp.com/ |
10-20-2018, 04:51 PM
I've seen the pi1541. I don't have the space for HP stuff, Amiga stuff and c64 stuff so I don't have any at the moment.
10-20-2018, 05:39 PM
I want one of these
http://obsolescence.wixsite.com/obsolesc...11-get-one |
10-22-2018, 05:00 PM
(This post was last modified: 10-22-2018 05:01 PM by toml_12953.)
(10-19-2018 06:07 PM)Albert Chan Wrote:Remind me not to use the ATM after you do!(10-19-2018 03:31 AM)Garth Wilson Wrote: BTW, I absolutely loathe touch screens—the grime, the parallax, the lack of precision ![]() Tom L Cui bono? |
10-23-2018, 10:08 PM
Have you seen *old* electronic calculator that use Piano Wire for memory ?
FYI, that was Cliff Stoll, author of "Cuckoo's Egg" |
10-24-2018, 02:03 AM
We had a good conversation on the 6502.org forum about how the old computers had better response times than modern ones do:
http://forum.6502.org/viewtopic.php?f=1&t=4946 http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, http://wilsonminesco.com/links.html ) |
10-24-2018, 03:31 AM
I saw that one, problem is most are assuming modern computers all have a certain closed source OS, they don't realize you can load a more responsive OS.
10-26-2018, 11:12 PM
(10-24-2018 03:31 AM)EugeneNine Wrote: I saw that one, problem is most are assuming modern computers all have a certain closed source OS, they don't realize you can load a more responsive OS. All modern Intel computers run Minix inside the hardware backdoor spy chip. They also run another proprietary OS called UEFI. You’re running two OS’s before you even boot the machine. |
10-27-2018, 08:29 PM
(10-26-2018 11:12 PM)Sukiari Wrote:(10-24-2018 03:31 AM)EugeneNine Wrote: I saw that one, problem is most are assuming modern computers all have a certain closed source OS, they don't realize you can load a more responsive OS. I was referring to the OS the end user interacts with. Most on that thread are comparing their old computers to Win/MAC and wondering why the new suck so much. They don't realize you can run a decent OS on new PC's (Linux, minix, FreeBSD, AROS, etc) and get close to the same experience as old computers. |
10-28-2018, 07:04 PM
(This post was last modified: 10-28-2018 07:06 PM by toml_12953.)
(10-20-2018 05:39 PM)Zaphod Wrote: I want one of these I have one (as well as Oscar's PiDP-8) and can vouch for the quality of his kits. If you buy one you won't regret it (unless you're married to a practical woman!) I'm currently running BASIC on four serial terminals and still have a console free to do system changes. It's an amazing little kit! Tom L Cui bono? |
