terminal view to the main screen (history view) cmd
10-31-2018, 10:50 PM (This post was last modified: 11-03-2018 12:29 PM by compsystems.)
Hello, users and developer group of the famous hp-prime calculator
Sorry for my technical english.
In the following program
PHP Code:
#cas
prg00( ):=
begin
        local X
Y;
assume(Xsymbol); // elimina valor de X para asumirla como símbolo
assume(Ysymbol); // elimina valor de Y para asumirla como símbolo
PRINT; // Limpiar pantalla
print( "Hello Mathematical World" ); // Escribir "Hola  mundo matemático "
wait); // Esperar 2 segundos
print( 'X²/3 - Y²/5 = 1'  );
wait);
        PRINT;
        return
“Done”;
end;
#end
I have a question
How to return from the terminal view to the main screen (history view)?
for example in xCAS there is the DispHome() command
Thanks
JaiMeza
10-31-2018, 10:55 PM (This post was last modified: 10-31-2018 10:57 PM by eried.)
RE: terminal view to the main screen (history view) cmd
Syntax:
STARTVIEW(ViewNumber[,Redraw])
Starts a view of the current app. Redraw, is optional; if Redraw, is true (non 0), it will force a refresh for the view.
The view numbers are as follows:
0=Symbolic
1=Plot
2=Numeric
3=Symbolic Setup
4=Plot Setup
5=Numeric Setup
6=App Info
7=Views key
And NO... the Prime does not need a
STARTVIEWHOME()
command
My website: ried.cl
11-01-2018, 04:43 AM (This post was last modified: 11-03-2018 12:29 PM by compsystems.)
Hello Erwin
(10-31-2018 10:55 PM)eried Wrote:  And NO... the Prime does not need a STARTVIEWHOME() command
Why?
On the contrary, it is necessary, because the screen is small, it is a way of dividing the views
Quote:If ViewNumber is negative, the following global views are used:
-1=Home Screen
-2=Modes
-3=Memory Manager
-4=App Library
-5=Matrix Catalog
-6=List Catalog
-7=Program Catalog
-8=Note Catalog
?=CAS view
STARTVIEW( -1, 1 ); // return to HOME VIEW
Iseems that it does not work, please try the following code
PHP Code:
#cas
prg00( ):=
begin
        local X
Y;
assume(Xsymbol); // Remove the value of X to assume it as a symbol
assume(Ysymbol); // Remove the value of Y to assume it as a symbol
PRINT; // clear screen.
print( "Hello Mathematical world" );
wait); // Wait 2 seconds
wait);
        PRINT;
STARTVIEW( -1); // return to HOME VIEW
return “Done”;
end;
#end
The equivalent in xcas is
PHP Code:
prg00():={
local XY;
DispG;  // Initialize terminal view and graphic view.
ClrIO // clear screen.
print( "Hello Mathematical world." );
WAIT); // Wait 2 seconds
printf//1  ); // Print in 2D readable printing (Pretty Print)
WAIT);
ClrIO
DispHome // return to HOME VIEW
return “Done”;
And it works well, that is to say it is executed from the main view that in xcas is called worksheet then it opens the terminal view and at the end it returns to the terminal view, without having to press the key [esc]
JaiMeza
