ListExtras: A teaser for Listextensions on the Prime
11-01-2018, 06:17 PM (This post was last modified: 11-02-2018 07:43 PM by StephenG1CMZ.)
Here is a teaser for List Extras...Totally untested.
I already have a collection of list routines in my List, Means and SortL programs.
ListExtras aims to eventually implement relevant functionality on the Prime comparable to DavidM's Listextensions for the HP48..HP50 family, to assist portability between the two platforms.
The current teaser should be considered untested pseudocode...
i wanted to put something online just in case.
 LOCAL CRID:="ListExtras API V0.01 © 2018";
 LOCAL MORETEXT:="ListExtras by StephenG1CMZ on HP Prime\nInspired by DavidM's Listext on HP48-50.";
 LOCAL MN:="ListExtras.";//Name
 //IMPORT({List});        //Required
 //IMPORT({Means,SortL}); //Required
 LOCAL TP;
 LOCAL ExBool:=0;//Request Exact//MEX
 LOCAL NOVALERR:=ListIsEmptyError;//LPOP
 LOCAL BADDIMERR:=ListIsEmptyError;
 //Forward
 LNMRL(LST);
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
  MSGBOX("An early teaser...\nTotally untested");
 TBD()
  MSGBOX(MN+"TBD");
 EXPORT ArrangeFunctions()
 EXPORT LRLLD(LST)
 //INVERSE ROTATE (=−1 ROT)
  LOCAL HD:=LST(1);
  RETURN CONCAT(ListAFTER(LST,1),HD);
 EXPORT LROLL(LST)
 //ROTATE (=1 ROT)
  LOCAL LAST:=LST(0);
  RETURN CONCAT(LAST,ListBEFORE(LST,SIZE(LST)));
 EXPORT LROT(LST,ROTNUM)
 //ROTATE A LIST NUM POSITIONS (NUM SIGNED)
 //NEED -1 REPEATEDLY TBD
  LOCAL II;
  IF ROTNUM THEN
   TBD();
   FOR II FROM 1 TO ABS(ROTNUM) DO
    IF ROTNUM>0 THEN
     RETURN LROLL(LST);
    ELSE
     RETURN LRLLD(LST);
  RETURN LST; //NO ROT
 EXPORT LSWAP(LST,POSN1,POSN2)
 //SWAP 2 ELEMENTS
  LOCAL TMP:=LST(POSN1);
  LST(POSN1):=LST(POSN2);
  LST(POSN2):=TMP;
 EXPORT LSSR(LST,POSN1,POSN2)
 //REVERSES PART OF A LIST, RETURNS WHOLE LST
 //EXT: POSN>0 INCLUDED (NULL=POSN=0)
  LOCAL TMP:=REVERSE(ListSLICE(LST,POSN1,POSN2));
  LOCAL BEF:=ListBEFORE(LST,POSN1);
  LOCAL AFT:=ListAFTER(LST,POSN2);
  ListANS:=CONCAT(BEF,CONCAT(TMP,AFT));
  RETURN ListANS;
 EXPORT LSHUF(LSTNUM)
 //SHUFFLES LST
  RETURN ListSHUFFLE(LSTNUM);
 EXPORT REV(LstStN)
 //EXT: REVERSE LISTS STRINGS N
 //THIS IMPLEMENT ALSO DOES SUBLISTS
 //QUERY DO WE NEED? DOES BUILTIN REVERSE SAME?
    TP:=TYPE(LstStN);
    CASE
    IF TP==TYPELST THEN RETURN REVERSE(LstStN); END;
    IF TP==TYPESTR THEN TBD(); END;
    DEFAULT
 EXPORT EditFunctions()
 EXPORT LDDUP(LST)
 //EDIT:REMOVE DUPLICATES
 //EXT:SAME SEQ
 //X:NATIVE SEEMS TO
  RETURN ListREMOVEDUPLICATES(LST);
 EXPORT LHDTL(LST)
 //EDIT: AKA LPOP. NULL=NOVAL ERR
 //X: Tail in ListANS. NULL=ListIsEmptyError
  RETURN ListHEAD(LST);
 EXPORT LINSR(LST,POSN,ITEMS)
 //EDIT: INSERT ITEM(S) AKA LINSRT
 //INSERTS 1 ITEM OR A LIST OF ITEMS
 //QUERY: HOW TO INSERT 1 ITEM OF TYPE LST?
 //EXT: POSN<2 NEEDS HANDLING
 //X: EXT COMPATABILITY TBD
  RETURN ListINSERT(LST,POSN,ITEMS);
 EXPORT LINSRT(LST,POSN,ITEMS)
 //AKA LINSR
  RETURN LINSR(LST,POSN,ITEMS);
 EXPORT LFIRST(LST,NUM)
 //EDIT: RETURN FIRST ITEMS AKA LFRST
 //GUARDS AND NEGATIVES TBD
 //EXT: N<0 UNK ERR N==0 NULL
 //X:NO ERROR YET
  RETURN ListBEFORE(LST,NUM+1);
 EXPORT LFRST(LST,NUM)
 //AKA LFIRST
  RETURN LFIRST(LST,NUM);
 EXPORT LLAST(LST,NUM)
 //EDIT: RETURN LAST ITEMS
 //EXT: N<0 UNK ERR 0 NULL N>LST LST
 //X: GUARDS AND NEGATIVES TBD
  LOCAL POSN:=SIZE(LST)-NUM;
  RETURN ListAFTER(LST,POSN);
 EXPORT LPICK(LST,GETLST)
 //EXT:EMPTY GET=NULL
  RETURN ListGETLIST(LST,GETLST);
 EXPORT LPOP(LST)
 //EDIT: AKA LHDTL
  RETURN LHDTL(LST);
 EXPORT LPOPR(LST)
 //EDIT: POP LAST ITEM
 //EXT: NULL=NULL AND NOVAL ERR
 //X: ERR TBD
  IF SIZE(LST) THEN
   ListANS:=ListBEFORE(LST,SIZE(LST));
   RETURN LST(0);
  ListANS:={};
  RETURN {};
 EXPORT LPSHR(LST,ITEM)
 //EDIT: PUSH ITEM TO RIGHT OF LST
 //EXT: ITEMTYPE=LST:PUSH 1 ITEM NULLNULL={{}}
 //X: TBD NULL GUARDS CF LPUSH
  LST(0):=ITEM;
 EXPORT LPUSH(LST,ITEM)
 //EDIT:ADD ITEM TO FRONT
 //EXT NULLNULL={{}}
 //TBD:NULL GUARDS DONT WORK
 //LATER:USE GUARDS IN LIST
  IF LST=={} THEN
   RETURN {ITEM};
  IF ITEM=={} THEN
   RETURN CONCAT({},LST);
  RETURN ListINSERT(LST,1,ITEM);
 EXPORT LRCL(LST)
 //EXT:({A}) -> 5 IF A IS 5
 //X: ({"2+3"}) -> 5 ==> NOT THE SAME
  LOCAL II;
  ListANS:={};
  FOR II FROM  1 TO  SIZE(LST) DO
   ListANS(0):=EXPR(LST(II));
  RETURN ListANS;
 EXPORT LREPL(LST,TARGETLST,REPLLST)
 //WHEN TARGETLSTn EXISTS IN LST
 //REPLACE IT WITH REPLLSTn
 //RETURN MODIFIED LST
 //Hint: CALL ListREPLACE FOR EACH n
 //QUERY: WHAT HAPPENS IF CHANGED TWICE
  LOCAL II;
  ListANS:=LST;
  //Can this be more efIcient?
  FOR II FROM 1 TO SIZE(TARGETLST)  DO
   ListANS:=ListREPLACE(ListANS,TARGETLST(II),REPLLST(II));
  RETURN ListANS;
 EXPORT LRMOV(LST,POSNS)
 //EDIT: REMOVE ITEMS
 //EXT: REMOVE MULTIPLE POSNS IGNORING DUPLICATE POSNS
 //X: SINGLE POSN ONLY FOR NOW
  IF TYPE(POSNS)==TYPELST THEN
   TBD();
  RETURN ListREMOVEX(LST,POSNS);
 EXPORT GroupFunctions()
 EXPORT GrpLCLLT(LSTS)
 //List Collate. INVERSE OF LDIST
   LOCAL II,JJ;
   LOCAL SIZE1:=SIZE(LSTS(1));
   ListANS:={};
   //REQUIRE ALL SIZES SAME
   FOR II FROM  1 TO SIZE(LSTS) DO
    IF SIZE1≠SIZE(LSTS(II)) THEN
     RETURN "BAD DIM";//UNK ERR
   //OK, COLLATE
   FOR JJ FROM  1 TO SIZE1 DO
    FOR II:=1 TO SIZE(LSTS) DO
     ListANS(0):=LSTS(II,JJ);
 EXPORT LDIST(LST,NUM)
 //DISTRIBUTE ITEMS INTO NUM SUBLISTS.INVERSE OF LCLLT. CF LSDIV
 //EXT: NUM MUST EVENLY DIVIDE LISTSIZE. UNK ERR
 //HINT REPEATEDLY CALL ListBEFORE
  TBD();
 EXPORT LGRP(LST)
 //GROUP REPEATED ELEMENTS IE NO DUPLICATS
 EXPORT LRPCT(LST)
 //LIST LGRP ELEMENTS AND COUNTS
 //EXT: NULL={{},{}}
 //X:DITTO
  RETURN ListCOUNTS(LST);
 EXPORT LRPCTo(LSTVLSTF)
 //INVERSE
  LOCAL LSTV:=LSTVLSTF(1);
  LOCAL LSTF:=LSTVLSTF(2);
  RETURN ListUNCOUNTS(LSTV,LSTF);
 EXPORT LSDIV(LST,SUBSIZE)
 //SPLIT A LIST INTO LISTS OF SIZE SUBSIZE. CF LDIST
 //EXT: NO REMNANT. UNK ERR.
  TBD();
 EXPORT LXIL(LST)
 //FLATTEN TOP LISTS
  RETURN ListFLATTENTOP(LST);
 EXPORT LXILR(LST)
 //FLATTEN LISTS RECURSIVELY
  RETURN ListFLATTENALL(LST);
 EXPORT RSPLT(LstStN,RSIZE)
 //RIGHT SPLIT Lst St Or N. SZ=IP(RSIZE)
 //EXT:LST: RETURN 2 LISTS, RIGHT OF SIZE RSIZE
 //SIMILARLY FOR ST AND N
  TBD();
 EXPORT SPLIT(LstStN,LSIZE)
 //SPLIT A Lst St OR N. (IE LSPLT CF RSPLT) SZ=IP(LSIZE)
  TBD();
 EXPORT SLISTTo(LST)
 //EXT:SAFE LST AVOIDING GARBAGE COLLECTION
 //X: IRRELEVANT?
  RETURN LST;
 EXPORT MakeFunctions()
 EXPORT MakeLASEQ(FRM,CHNG,NUM)
  LOCAL XX;
  RETURN IFTE(NUM>0,MAKELIST(FRM+(CHNG*XX),XX,0,NUM-1),{});
 EXPORT MakeLDSEQ(FRM,CHNG,NUM)
   LOCAL XX;
   IF CHNG==0 THEN
    RETURN "NaN";//DIVBY0
   IF (TYPE(FRM)==TYPE(CHNG) AND TYPE(CHNG)==TYPEINT) OR ExBool THEN
    RETURN IFTE(NUM>0,MAKELIST(exact(FRM/(CHNG^XX)),XX,0,NUM-1),{});
    RETURN IFTE(NUM>0,MAKELIST(FRM/(CHNG^XX),XX,0,NUM-1),{});
 EXPORT MakeLMSEQ(FRM,CHNG,NUM)
   LOCAL XX;
   RETURN IFTE(NUM>0,MAKELIST(FRM*(CHNG^XX),XX,0,NUM-1),{});
 EXPORT MakeLSEQ(CNT)
 //Create CNT REAL integers
 //Return Real integer (No N)
  LOCAL XX;
  RETURN ListANS:=IFTE(CNT,MAKELIST(XX,XX,SIGN(CNT),CNT),{});
 EXPORT MakeLSEQR(FRM,TOO)
  LOCAL XX;
  RETURN ListANS:=IFTE(TOO-FRM,MAKELIST(XX,XX,FRM,TOO),{});
 EXPORT MakeLMRPT(ITEMS,RPTCNT)
  IF RPTCNT<0 THEN
   RETURN {};//OR NEGATE
  IF TYPE(ITEMS)≠TYPELST AND RPTCNT==1 THEN
   //GUARD AGAINST SINGLE ITEM ONCE NOT RETURNING A LIST
   RETURN MakeLMRPT({ITEMS},RPTCNT);
  IF RPTCNT>1 THEN
   RETURN CONCAT(ITEMS,MakeLMRPT(ITEMS,RPTCNT-1));
  RETURN IFTE(RPTCNT,ITEMS,{});
 EXPORT MathFunctions()
 EXPORT LMAX(LST)
 //EXT: CAN ALSO MAX LISTS OF STRINGS
 //EXT: NULL=INVALID DIM
 //X: NUMERICS ONLY
  //RETURN ListMAX(LST);
  RETURN MAX(LST);
 EXPORT LMIN(LST)
 //EXT: CAN ALSO MIN LISTS OF STRINGS
 //X: NUMERICS ONLY
  //ListMIN NOT IMP?
  RETURN MIN(LST);
 EXPORT LSUM(LST)
 //HANDLES NULL
  //RETURN ListΣLIST(LST);
 EXPORT LPROD(LST)
 //HANDLES NULL
  //RETURN ListΠLIST(LST);
 EXPORT SortFunctions()
 EXPORT KSORT(LST,KEYLST)
 //EXT:NULL KEY RETURNS TARGET UNCHANGED
 //EXT:NULL TARGET AND NON NULL KEY=BAD DIM
 //RETURN 2 LISTS
  RETURN SortByKeyLST(LST,KEYLST);
 EXPORT KSORTFUN(LST,KEYLST,KEYFUNC)
 //Pysort implements sort functions
 //NB The ext list sequence is not implemented
  MSGBOX("Use SORTL.Pysort");
 EXPORT StringFunctions()
 EXPORT StringLOCASE(ST)
 //EXT:ST
 //X-ALSO LST
  RETURN LOWER(ST);
 EXPORT StringUPCASE(ST)
 //EXT:ST
 //X-ALSO LST
  RETURN UPPER(ST);
 EXPORT RPTCHR(ST,RPTCOUNT)
 //QUERY: IN EXT IF STRING IS >1 CHAR
 //IS THE COUNT THE NUMBER OF REPETITIONS OF STRING
 //OR NUMBER OF CHARACTERS
 //(REPETITIONS EASIER?)
 //HINT I HAVE IMPLEMENTED THIS RECURSIVELY IN A PROGRAM
  TBD();//BUT WHERE
 EXPORT TestFunctions()
 EXPORT LCNT(LST,ITEM)
 //NB TO COUNT ITEM=LISTS SEE IMPLEMENT
  RETURN ListCOUNTITEMS(LST,ITEM);
 EXPORT LEQ(LST)
 //TST ALL ITEMS IN 1 LST ARE SAME
 //EXT: NULL OR SIZE 1 RETURNS TRUE (NO NON-MATCHES)
  LOCAL XX;
  LOCAL TMP:=LST(1);
  ListANS:=MAKELIST(TMP,XX,1,SIZE(LST));
  RETURN EQ(LST,TMP);
 EXPORT MPOS(LstSt,ITEM)
 //Find ITEM in Lst or St
  IF TYPE(LstSt)==TYPELST THEN
   RETURN ListFIND(LstSt,ITEM);
  ELSE
   TBD();
 EXPORT MPOSL()
 //AS MPOS BUT IF LSTn IS A LIST, MATCH IN THERE TOO
 //BUT NOT FULLY RECURSIVEO JUST ONE LEVEL
  TBD();
 EXPORT LNMRL(LST)
 //EXT:NORMALISE COMPRESSES LST
 //X:NOP
  RETURN LST;
 EXPORT LSAME(LST1,LST2)
 //EXT: IMPLEMENTS LMRL SAME
  RETURN EQ(LST1,LST2);
 EXPORT ThatsAllFunctions()
 EXPORT LISTEXTRAS()
Stephen Lewkowicz (G1CMZ)
11-02-2018, 12:41 PM
RE: List Extras: A teaser for Listextensions on the Prime
Nice, no time to test it but it is great that you put effort on it and shared it Smile
