(11C) Generate Pair of Parallel Resistors
10-26-2018, 11:47 AM
Program to generate in endless loop of
Two Parallel Resistors with your desire total. This program give different pair of resistors that match the giving total. Procedure: [A] // Total [ENTER] Step [A] [B] // Press any key to Stop Loop [B] 1st Resistor [R/S] 2nd Resistor [R/S] continue forward loop. [C] // [C] Backward loop, Press any key to Stop Loop [B] 1st Resistor [R/S] 2nd Resistor. [E] Initialize --------------------------------------------------- Example: FIX 3 Destination total is 25.75 Pick two difference pair of resistors of your choice. I will use 0.5 for loop steps. [E] Initialize 25.75 ENTER .5 [A] ---->Program keep generate two resistors that match your giving total in this case is 25.75 Once you see the pair you like press any key to stop I recommend ENTER key. [B] I pick this pair: 30.25 [R/S] 173.097 [R/S] --> Continue Loop Forward [C] This loop go backward: Once you see the pair you like press any key to stop. I pick this pair: --> [B] 28.250 [R/S] 290.975 --------------------------------------------------------- Program: Code:
Gamo |
10-27-2018, 06:00 AM
RE: (11C) Generate Pair of Parallel Resistors
Program use for total up even numbers of the "Same Resistors Value" in Parallel.
Procedure: Resistor Value [ENTER] even number of resistors [A] Example: What is the total of 3 pair of 15 ohm Restistors in Parallel? 15 ENTER 6 [A] Answer: 2.5 ohm ----------------------------------------------------------------- Program: Code:
Gamo |
10-27-2018, 10:51 AM
(10-27-2018 06:00 AM)Gamo Wrote: What is the total of 3 pair of 15 ohm Restistors in Parallel? You can improve that program a bit: Code: LBL A Or then just use the dedicated key: [÷] Kind regards Thomas BTW: Your program doesn't work properly unless the register 6 is initialised to 0. It doesn't help that you are doing it at the end of the program. |
10-29-2018, 05:28 PM
(10-26-2018 11:47 AM)Gamo Wrote: Program to generate in endless loop of Gamo, after looking at this program for a few days I still do not understand where it may be usedful. Could you describe a practical application? (10-26-2018 11:47 AM)Gamo Wrote: Destination total is 25.75 OK. You now know that 25,75 Ω equals 30,25 Ω and 173,097 Ω in parallel. But where do you get such resistors from?! What about a different program: store the resistors that you have in R1, R2, R3, ... and let the program calculate the combinations that come close to a certain target resistance. Dieter |
