draw a line into a plot
11-02-2018, 04:40 PM
Hello
I would like to generate a logarithmic grid in the plot view. If i am right, there is no possibility to show a logarithmic grid in the plot view right? Therefore i would like to draw the neccessary lines by myself. is there a method to draw into the plot view? One possibility would be to add a function with nearly unlimited slope. thanks |
11-03-2018, 09:36 AM
RE: draw a line into a plot
What about the background function? Plot/Setup (page 2)
My website: ried.cl |
11-03-2018, 12:21 PM
(This post was last modified: 11-03-2018 12:22 PM by blevita.)
(11-03-2018 09:36 AM)eried Wrote: What about the background function? Plot/Setup (page 2) Great idea. Have tested this right now. It would work perfectly but the HP resized my image. See the attached pictures. Is there a way to save a high-res image to the prime? |
11-03-2018, 02:46 PM
(This post was last modified: 11-03-2018 02:47 PM by eried.)
(11-03-2018 12:21 PM)blevita Wrote: Is there a way to save a high-res image to the prime? Do not use the "Add background" (it downsamples the image quite a bit). Just import the png as a file, you can use sharp massive files in this way: Use the XY range option to position your image, just keep the width and height matching your image. My website: ried.cl |
11-03-2018, 02:53 PM
works great!
Thank you very much |
