very large numbers in display
11-04-2018, 08:44 PM
One of the new features of the new update (14181 2018.1016) is the resizing of very large numbers in the display. example 150! The older versions would go all the way too 1000!
Previous to this update you would all of the digits in the answer in cas. Now
you get the condensed shorten answer. My question is how can I get the
answer with all of the digits included ?? is there a work around ?? Thoughts.??
11-04-2018, 09:23 PM
RE: very large numbers in display
Double click the condensed answer (double tap the screen in the real calc).
OR
Click (tap) the condensed answer and press Show.
Josep Mollera. HP PRIME, HW: C, SW: 2.2.15157 (2024-09-01).
11-04-2018, 09:30 PM
Thanks JMB !! That works. I should have tried that before I posted. I look
forward to your posts.
