(41C) Roll 2 Dice at Random
11-08-2018, 06:34 AM
This is another implementation from my previous post on HP-11C but this one
use different RANDOM algorithm.
Here is the program to Roll Two Dice at Random.
Procedure: Assign [Rv] to run program
First start must create SEED on Register 09 [STO 09]
SEED STO 09
[Rv] x.x // Integer Part is 1st Dice and Fractional Part is 2nd Dice
Example:
I put 0.1234 as a SEED on Register 09
.1234 STO 09
[Rv] 5.4 // 5 and 4
[Rv] 1.2 // 1 and 2
[Rv] 5.6 // 5 and 6
Program:
LBL 2DICE
XEQ 01
STO 00
XEQ 01
STO 01
10
XEQ FRC
STO 02
FIX 1
RCL 00
RCL 02
RTN
LBL 01
RCL 09
LN
E2
x
1
XEQ MOD
STO 09
6
x
1
XEQ INT
RTN
Assign Key to run program:
ASN ALPHA 2DICE ALPHA [Rv]
Gamo
11-09-2018, 07:44 PM (This post was last modified: 11-09-2018 07:45 PM by Dieter.)
RE: (41C) Roll 2 Dice at Random
(11-08-2018 06:34 AM)Gamo Wrote:  This is another implementation from my previous post on HP-11C but this one
Gamo, why does this program waste no less than four (!) data registers just for adding two random numbers?
In R01 you even store a value which is never recalled afterwards. Actually this program dues not require any registers at all – except the one for the seed.
LBL "2DICE"
XEQ 01
XEQ 01
10
FIX 1
RTN
The RNG looks interesting, but it can cause problems. Why? Try a seed of 0,006737947 or 0,0982735856 or 0,3328710837.
BTW, in an HP41 program you can simply write "FRC", "MOD" and "INT" instead of "XEQ FRC", "XEQ MOD" and XEQ INT".
Dieter
