IFTE function cmd and store cmd
11-12-2018, 05:57 PM (This post was last modified: 11-12-2018 06:58 PM by compsystems.)
I want to extract the "TRUE" values from an array
[ false, false, true, true ] => [ true, true ]
In the following code there is a problem when trying to store a variable within IFTE function cmd
if I delete y: = or ▶y it works but the value of y is not updated
PHP Code:
#cas
test_IFTE( ):=
begin
  local x
yz;
:= 1
:= [ falsefalsetruetrue ];
index := 1;
REPEAT
    ifte
z[x] == true,  concatytrue )▶ynop );
x++;
until
    x
== 5;
  return
y;
end;
#end
[Check] No errors in the program
test_IFTE() [Enter] returns
Quote:1,[0,0,true,true,true] ???
[ true, true ] // ok
PHP Code:
iftez[x] == true,  := concatytrue ), nop );
// also fails
Quote:"for([0,1,0,{
ifte(((z[x])==true),y:=concat(y,true),'nop');
x++;
IF x = 5 THEN BREAK ; END ;
}]) in [test_IFTE] instruction #7 error, try debug([test_IFTE])
Error: Bad Argument Value"
REQUEST: An alternative or simpler code with functions cmd and not block of structures?
11-12-2018, 09:17 PM
RE: IFTE function cmd and store cmd
try;
EXECON("IF &1==true THEN L0:=concat(L0,true); L0:=L0[0]; ELSE nop; END;",[false,false,true,true,true,false,true])
11-12-2018, 09:25 PM
Or simply :
z:=[false,false,true,true,true,false,true]
remove(false,z)
11-13-2018, 06:06 AM
Be carefull, EXECON is a home command, not a cas command.
Cyrille
