(12C Platinum) Reverse Factorial
11-27-2018, 08:29 AM (This post was last modified: 11-28-2018 12:11 PM by Gamo.)
Just acquired a brand new HP-12C Platinum and here is the first program for it.
This program also work on original HP-12C.
Program is use for reverse factorial.
If you know the number of ways and need to know what is the value of its Factorial.
Procedure:
Integer [R/S] display Factorial Integer
If Integer is not a perfect Factorial the answer will display "negative" Factorial integer,
then switch stack display the + or - integer.
Integer [R/S] display Negative Factorial [X<>Y] +or- Integer
Remark: The negative result indicate that this is not a perfect factorial.
Example:
120 is what Factorial?
120 [R/S] display 5
Answer: 5!
555 is what Factorial?
555 [R/S] display -5 [X<>Y] 435
Answer: 5! + 435
Program: Reverse Factorial (RPN Mode)
001 STO 0
002 STO 1
003  2
004 STO 2
005 RCL 0
006 RCL 2
007  ÷
008 STO 0
009 RCL 2
010 X<>Y
011 X≤Y
012 GTO 016
013  1
014 STO+2
015 GTO 005
016  1
017 RCL 0
018  -
019 X=0
020 GTO 028
021 RCL 1
022 RCL 2
023 n!
024  -
025 RCL 2
026 CHS
027 GTO 000
028 RCL 2
Program for ALG Mode
001 STO 0
002 STO 1
003  2
004 STO 2
005 RCL 0
006  ÷
007 RCL 2
008  =
009 STO 0
010 RCL 2
011 X<>Y
012 X≤Y
013 GTO 017
014  1
015 STO+2
016 GTO 005
017  1
018  -
019 RCL 0
020  =
021 X=0
022 GTO 031
023 RCL 1
024  -
025 RCL 2
026 n!
027  =
028 RCL 2
029 CHS
030 GTO 000
031 RCL 2
Gamo
