Topic List # Limit
12-12-2018, 03:03 PM
Topic List # Limit
While expanding the EE_Analysis program, I discovered this limitation.
The Topic list is usually preceded by #1...9,A.......> Z? However I noticed that when the list exceeded M, the numbers 1 to 9 and Alphabet completely disappeared from the list. Why cannot the whole alphabet A ... Z be used? The only option is to navigate to the topic. Has anyone ever made a program where the list exceeded M topics? The only recourse is to shorten the list by bunching related categories similar to folders and sub-folders as is already used on some of the topics. |
12-12-2018, 03:49 PM
(This post was last modified: 12-12-2018 03:56 PM by Tim Wessman.)
RE: Topic List # Limit
Because the "hotkeys" are then covered by the 1-9 keys as they are the same as the alpha letters.
If you put a number in your text, the user can simply type to search by number if they want. Or they can press alpha and search that way. TW Although I work for HP, the views and opinions I post here are my own. |
12-12-2018, 06:15 PM
Thanks Tim
In other words stop staring at the screen and check the keyboard. There is a difference between seying and seeing. |
