HP-35e battery case
12-21-2018, 02:02 AM
HP-35e battery case
Can anyone source this [attachment=6685]battery case for the HP-35?
BEST! SlideRule |
12-21-2018, 02:04 AM
(This post was last modified: 12-21-2018 02:17 AM by calcphil12c11c.)
RE: HP-35e battery case
This is what you want. Just got one for my HP 67. Works perfect!
With rechargeable... https://www.ebay.com/itm/Rechargeable-HP...amflu:rk:1 ![]() |
12-21-2018, 02:44 AM
(12-21-2018 02:04 AM)calcphil12c11c Wrote: This is what you want. Just got one for my HP 67. Works perfect! That one uses 3 x AAA batteries, SlideRule is looking for a holder for 3 x AA batteries (much longer battery life between charge). That's an interesting holder SlideRule, I don't recall seeing that before. I hope someone knows where it is available. --Bob Prosperi |
12-21-2018, 02:48 AM
(This post was last modified: 12-21-2018 02:55 AM by calcphil12c11c.)
Just put in larger NiMH AAA like I did. You can get 1250 mAh AAA NiMH batteries.
12-21-2018, 04:12 AM
(This post was last modified: 12-21-2018 04:12 AM by Sylvain Cote.)
(12-21-2018 02:02 AM)SlideRule Wrote: Can anyone source this battery case for the HP-35?Hello SlideRule, If you had looked at the HP Calculator Parts [2018-08-10] article in the article forum ![]() You would had found under the Classic :35:45:55:65:70:80:67: section, Bob Wolfson Classic Battery Adapter. Sylvain |
12-21-2018, 06:58 AM
(12-21-2018 04:12 AM)Sylvain Cote Wrote:(12-21-2018 02:02 AM)SlideRule Wrote: Can anyone source this battery case for the HP-35?Hello SlideRule, Although... Quote:It's up to you to fashion the metal contacts and glue the assembly together. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
12-21-2018, 01:39 PM
(12-21-2018 06:58 AM)Massimo Gnerucci Wrote:(12-21-2018 04:12 AM)Sylvain Cote Wrote: Hello SlideRule, Hello Massimo, I have found Bob Wolfson web site and found that he is selling the complete assembled part for $40.00 USD --> HERE I also updated the HP Calculator Parts article to include Bob assembled parts & services. Sylvain |
12-21-2018, 02:02 PM
(This post was last modified: 12-21-2018 02:02 PM by SlideRule.)
THANKS ALL!
Best! SlideRule |
12-21-2018, 03:09 PM
(12-21-2018 01:39 PM)Sylvain Cote Wrote:(12-21-2018 06:58 AM)Massimo Gnerucci Wrote: Although... Great news Sylvain! Thank you. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
User(s) browsing this thread:
