HP Prime and units?
01-03-2019, 09:44 PM
HP Prime and units?
I've been considering purchasing the HP Prime and decided to test the HP Prime Lite Android app beforehand. I've encountered some oddities in how the app handles units. For example: 2.3_m/s^2 * 3_s does give the answer as 6.9_m/s But 2.3_m/s^2 * 3_mn gives the answer as 6.9_(m*mn)/s^2 In fact it would seem that any unit of time other then seconds results in similar odd units. Also 5_A * 8_V gives 40_(A*V) rather then 40_W and attempts at calculating kinetic energy, force exerted by pressure and several others give similarly odd answers. Is this just the app or does the calculator give the same odd answers? |
01-04-2019, 01:15 AM
(This post was last modified: 01-04-2019 01:20 AM by cdmackay.)
RE: HP Prime and units?
Follow the above with: USIMPLIFY(Ans)
edit: if you like the traditional approach, see also: http://www.hpmuseum.org/forum/archive/in...11395.html Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 71B 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot Casio, Rockwell 18R |
01-04-2019, 07:16 AM
Yes, it is generally a bad idea to attempt to convert complex units into other forms except on demand because there are so many possibilities.
