Highest number 50g kann handeln?
04-30-2014, 08:15 PM
I tipped in the function (1+e^x)/(1-e^x), draw it and then hit softmenu "FNC", then NEXT and F(X) and it displayies the result : 9.99999999999E499
04-30-2014, 08:59 PM
RE: Highest number 50g kann handeln?
(04-30-2014 08:15 PM)Alvaro Wrote:  I tipped in the function (1+e^x)/(1-e^x), draw it and then hit softmenu "FNC", then NEXT and F(X) and it displayies the result : 9.99999999999E499
You can also try the MAXR and MINR instructions:
MAXR ->NUM
MINR ->NUM
Gerson.
05-01-2014, 07:22 AM
That is only the highest floating point number the 50g handles. The largest integer number is limited by memory, since the 50g supports arbitrary precision integers.
It ain't OVER 'till it's 2 PICK
