(25) the Strong Shock Algorithm for Yield and Origin-Shift
01-05-2019, 04:05 PM
(This post was last modified: 01-12-2019 01:54 PM by SlideRule.)
The ABSTRACT from HP-25 program for solving the strong shock algorithm for yield and origin-shift, Los Almos Reports (LA-6799-MS), May 1977.
We present a program for the HP-25 hand calculator which solves the strong shock algorithm for yield and origin-shift. The program is intended for quick-look analysis of field data and could easily be modified and improved upon for use with other calculators having larger program and data memories. BEST! SlideRule |
