Print with HP 50G and HP 82240B
05-02-2014, 01:49 PM
can somebody give me a step by step instruction
to print with those combination?
I can´t print with my HP 50G and the HP 82240B.
With the HP 48GX it works perfect.
Roland
05-02-2014, 03:16 PM
RE: Print with HP 50G and HP 82240B
(05-02-2014 01:49 PM)Roland Wrote:  Hello,
Roland
Hi Roland,
ensure Flag 34 is set to "Print via IR", then push "APP", select "I/O functions". After that make your choice.
HTH, Günter
05-02-2014, 05:26 PM
(05-02-2014 03:16 PM)Guenter Schink Wrote:  ensure Flag 34 is set to "Print via IR", then push "APP", select "I/O functions". After that make your choice.
I do so. But, sometimes the printer works and
sometimes not. And I can´t say it happend on a
special cause. What makes me insane is that
this ****** printer works perfect with the HP 48GX.
Roland
05-02-2014, 05:53 PM
sometimes not.
I guess you're aware that the IR range is very limited on the hp 50g, but it doesn't hurt to remind: the printer and the calculator should be properly aligned and no more than one inch or so apart from each other.
Gerson.
