INTERMITTENT ERROR IN CAS WHILE USING SOLVE() WITH SYSTEM OF EQUATIONS.
01-21-2019, 03:45 PM
Sometimes in CAS, when using solve() with system of equations the result of solve is wrong, you have to turn OFF the HP PRIME and ON again and then the result of solve() is correct. It does not happen very often, but it does happen from time to time.
01-21-2019, 04:23 PM
RE: INTERMITTENT ERROR IN CAS WHILE USING SOLVE() WITH SYSTEM OF EQUATIONS.
Hi!, John P :
Try delete de RAM memory, with ON+Apps+Esc.
