problem in edit/paste (simulator)
01-22-2019, 07:35 PM
(This post was last modified: 01-22-2019 07:37 PM by compsystems.)
a small problem in edit/paste (simulator), when copying the next expression from a text file, a space is added before the symbol [ poly1[ 1, 2, 3 ] * poly1[ 4, 5, 6 ] copy paste poly1 [ 1, 2, 3 ] * poly1 [ 4, 5, 6 ] |
01-22-2019, 08:34 PM
RE: problem in edit/paste (simulator)
It's not a problem, I think it's part of the interpreter
Viga C | TD | FB |
01-22-2019, 10:05 PM
(This post was last modified: 01-22-2019 10:18 PM by informach.)
Hi!, In my HP PRIME emulator, with Software version 2.1.14181 (2018 10 16), CAS version : 1.4.9, is equal hen copy (Shift + View) and Paste (Shift + Menu).
01-22-2019, 10:21 PM
(01-22-2019 08:34 PM)Carlos295pz Wrote: It's not a problem, I think it's part of the interpreter is a problem because the prefixes were not taken into account before [], the same happens with set[] and list[] set[ a, a, b, c ] * set[ d, ee ] copy paste set [ a, a, b, c ] * set_[ d, ee ] with tuple[1,2] ok |
