Exact Fractions in Matrices
02-01-2019, 02:39 PM
Can matrices only display decimal approximations on the HP Prime?
Say I have the matrix
[ [ 0.5, 0.6 ], [ 0.7, 0.8 ] ]
and I want to display the matrix in the program as
[ [ 1/2, 3/5 ], [ 7/10, 4/5 ] ].
A friend asked me how can we do this?
QPI turns matrices into lists when converting to exact values.
The command exact is ignored in Home Mode.
I had no success with propfrac or partfrac.
Is there a command that works like the [ a b/c ] key? Any help will be appreciated. Thank you.
02-01-2019, 04:47 PM (This post was last modified: 02-01-2019 04:58 PM by grsbanks.)
RE: Exact Fractions in Matrices
I'm guessing the answer is no.
I just tried to create a matrix with fractions by direct input. While the fractions showed on the command line, as soon as I hit [Enter] they were replaced by approximate values.
Before pressing [Enter]:
After pressing [Enter]:
02-01-2019, 06:20 PM
It works in CAS with no probs.
02-02-2019, 04:19 AM
This is awkward but it works in Home:
CAS("string(exact(M1))")
<0|ɸ|0>
-Joe-
02-02-2019, 04:21 PM
Hi!, Eddie :
Try by creating any algorithm with p/q Form, as ...
Attached File(s) Thumbnail(s)
02-02-2019, 11:21 PM
(02-02-2019 04:19 AM)Joe Horn Wrote:  This is awkward but it works in Home:
It does... except that the matrix is one line. I'm surprised that QPI does not make all the entries of a matrices in exact fraction form.
Thank you.
02-03-2019, 11:37 PM
(02-02-2019 11:21 PM)Eddie W. Shore Wrote:  I'm surprised that QPI does not make all the entries of a matrices in exact fraction form.
It does, but it also converts the matrix into a list of lists, because Home does not support symbolic matrices, only matrices of reals. So if you want a symbolic matrix, you'll either have to do it in CAS (or a CAS program), or convert the symbolic matrix into a form that Home can tolerate, such as a list of lists or a string. I personally like the QPI solution, even though its accuracy cannot be tuned as finely as the 'exact' function can.
Disclaimer: I *think* the above is correct, but I've almost entirely given up trying to learn how to use the HP Prime. Attempting to wrap one's brain around a constantly-moving target which is also a shape-shifter surrounded by an intermittent cloaking device is painful.
<0|ɸ|0>
-Joe-
02-04-2019, 02:20 AM
(02-03-2019 11:37 PM)Joe Horn Wrote:  Disclaimer: I *think* the above is correct, but I've almost entirely given up trying to learn how to use the HP Prime. Attempting to wrap one's brain around a constantly-moving target which is also a shape-shifter surrounded by an intermittent cloaking device is painful.
Yikes!
But there is good news here, as this is almost certainly the first time I discovered something about an HP machine before Joe did...
02-04-2019, 02:04 PM
I would love to have a program command that works like the [a b/c] key.
02-04-2019, 02:40 PM
Is it my imagination or is QPI() not documented anywhere (other than in the Toolbox Catlg)? I can't find it in the User Guide.
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 71B 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot
Casio, Rockwell 18R
02-05-2019, 02:13 AM
(02-04-2019 02:40 PM)cdmackay Wrote:  Is it my imagination or is QPI() not documented anywhere (other than in the Toolbox Catlg)? I can't find it in the User Guide.
Correct. Like many other recently-added functions (including my favorites, dfc and dfc2f), QPI has not yet been added to the User Guide.
<0|ɸ|0>
-Joe-
02-05-2019, 03:26 PM
<scrambles to look those up…>
thanks Joe.
Some time ago someone posted a nice HTML version of the help file, which I downloaded. Sadly I can't remember whence it came, but it's the only doc I have that mentions QPI, and it's a lot easier to search than the one on the calc, even with the emulator.
Cambridge, UK
Casio, Rockwell 18R
02-06-2019, 05:35 AM
(02-05-2019 03:26 PM)cdmackay Wrote:  Some time ago someone posted a nice HTML version of the help file, which I downloaded. Sadly I can't remember whence it came...
Did you mean this thread?
Geocaching Coords Solver, Number of triangles Puzzle
02-06-2019, 02:39 PM (This post was last modified: 02-06-2019 02:40 PM by cdmackay.)
oh! It was TimW, how embarrassing for me to forget. Yes, that was it, thanks very much indeed.
edit: and your version too, thanks! Smile
Cambridge, UK
Casio, Rockwell 18R
