(29C) Phase-Locked Loop Design Articles
02-01-2019, 09:35 PM
An extract from Phase-Locked Loop Design Articles, Mototola, AR254/D
Analyze, don't estimate, phase-lock-loop performance of type-2, third-order systems a small programmable calculator, the HP-25, easily -and exactly- determines the complete loop transfer function in 48 steps. Optimize phase-lock loops to meet your needs-or determine why you can't This article will show you how to optimize … a type-2, third-order PLL system with a 48-step program for an HP-25 programmable calculator … to your requirements. Suppress phase-lock-loop sidebands without introducing instability The first two parts of this series showed how to analyze and then optimize type-2, third-order PLL systems and provided simple calculator programs for an HP-25 to do the otherwise tedious computations. This article takes you a step further and shows how to suppress sidebands, especially undesired when the PLL is used in frequency-synthesis systems. Programmable calculator computes PLL noise, stability Calculate the noise spectral density and short-term frequency stability in a PLL with a programmable calculator, and vary the parameters to trade off the noise/functional performance requirements. the first three programs in HP-25 notation are HP-29C compatible. BEST! SlideRule |
