new Exact Arithmetic mode
02-03-2019, 01:57 PM
(This post was last modified: 04-19-2021 06:57 PM by compsystems.)
/!\ built in firmware 2021
Hello The new firmware of the Ti-nspire series, offers a third mode: the Exact Arithmetic mode, I think that this characteristic is essential in the numeric mode of the hp-prime without entering the CAS mode or without pressing the [a b/c] key ![]() Also numworks has an important feature is that it shows the result in approximate and exact form sqrt(24) [enter] 2*sqrt(6) ~= 4.898979... ![]() |
02-03-2019, 02:23 PM
(This post was last modified: 02-03-2019 02:24 PM by informach.)
RE: new Exact Arithmetic mode
Hi!, compsystems :
With the HP PRIME, you too can obtein, but in aproximate mode with (a b/c). |
02-03-2019, 09:51 PM
(02-03-2019 01:57 PM)compsystems Wrote: Hello Hasn't the NSpire CAS always offered a choice between "Auto", "Exact", and "Approximate" calculation mode? But your screenshot looks different. Which version is that taken from? Quote:Also numworks has an important feature is that it shows the result in approximate and exact form, (good point to clone) It does seem to get better. It was quite poor in some areas when it first came out, but that looks like a nice feature! — Ian Abbott |
02-04-2019, 08:12 AM
(02-03-2019 09:51 PM)ijabbott Wrote:(02-03-2019 01:57 PM)compsystems Wrote: Hello The new firmware (probably v5.0.0.0, a major release) is not out yet … it'll be out along with the new CX II (approximately at March 2019) and … frankly I'm not sure that will be more or less compatible with the "old" CX … let's wait and see ![]() Best, Aries ![]() |
