(HP-67/97) Naval Applications: Ten Algorithms …
02-04-2019, 11:17 PM
(This post was last modified: 02-05-2019 10:35 PM by SlideRule.)
An extract from NAVAL APPLICATIONS: TEN ALGORITHMS FOR THE HEWLETT-PACKARD HP-67 AND HP-97 CALCULATORS, Naval Postgraduate School, Report Number NPB55-79-04, FEB 1979
ABSTRACT Ten algorithms pertaining to underwater acoustics target motion analysis, P-3 mission planning, flight crew management, and naval gunfire support conversion are presented along with programs for Hewlett-Packard HP-67 and HP-97 programmable calculators. CONTENTS ACTIVE SONAR ACQUISITION THREE ENGINE AVAILABLE RANGE REMAINING MISSION PLANNING USER-CONTROLLED SIMULATION OF APPROACH AND LANDING FLIGHT CREW MANAGEMENT TARGET MOTION ANALYSIS (TMA) OF A BEARINGS ONLY TARGET FROM A MOVING PLATFORM. NAVAL GUNFIRE SUPPORT GRID SPOT CONVERSIONS NORMAL MODE THEORY NORMAL MODE TRANSMISSION LOSSES GOLDEN SECTION SEARCH INTRODUCTION This report contains a collection of programs … All programs were listed using an HP-97 with HP-97 key codes. The corresponding HP-67 key codes may be found on pages 324 through 331 of the "HP-67 Owner's Handbook and Programming Guide. BEST! SlideRule |
02-04-2019, 11:48 PM
RE: (HP-67/97) Naval Applications: Ten Algorithms …
Thank you for the link.
02-04-2019, 11:52 PM
RE: (HP-67/97) Naval Applications: Ten Algorithms … | |||
02-05-2019, 10:15 PM
Very appreciated, thank you very much.
Cheers JL |
