Algebraic manipulation
02-07-2019, 08:12 PM
How can I manipulate a algebraic expression trying to extract a used defined term.
Exemple:
(4x-12) --> I know I can factor this term. Does exists any kind of control that I can specify a term?
I would like to specif "(x-3)" --> 4.(x-3)
Another Exemple:
(3-(4/5x)-(-5) --> I would like to specify a term "(x-10)" and see it´s possible.
Does the calculator can do that? Or any alternative?
Thanks
02-08-2019, 01:04 AM
RE: Algebraic manipulation
I don't know of a way to use a specific factor.
Alternatives:
  • Use the factors() command to get a list of the factors. You can then inspect the list to see if the one you are expecting is present.
  • Or, do a test divide by your factor, e.g. simplify((4*x-12)/(x-3))? If your divisor remains unchanged then it isn't a factor.
02-08-2019, 09:52 AM
I think "factor()" and "simplify" will do the trick Wink
Oh … and make sure you're in the CAS "ambient" !
Best,
Aries Smile
02-08-2019, 05:37 PM
Usually , I ´ve been using the factor and simplify command as mentioned. But I would like to specify a factor if possible... Smile
Thanks
Best,
Mario
02-09-2019, 10:48 PM
Bruce,
I like your strategy the best - use the simplify(p(x)/q(x)).
The CAS program specfactor uses this strategy to factor q(x) from p(x):
#cas
specfactor(p,q):=
LOCAL r;
r:=simplify(p/q);
IF numer(r)==p THEN
RETURN r;
ELSE
RETURN "("+STRING(r)+")"+"*("+STRING(q)+")";
#end
Successful factoring returns the result as strings (to preserve the format without automatic simplification):
specfactor(4x-12,x-3) returns "(4)*(x-3)" [ 4(x-3) ]
specfactor(8-4/5*x,x-10) returns "(-0.8)*(x-10)"
specfactor(x^3 -x^2+2*x-2,x^2+2) returns "(x-1)*(x^2+2)"
Eddie
