HP67 Card Reader
02-10-2019, 03:42 AM
HP67 Card Reader
Hi all,
Seeing as he HP67 card reader is cramped and not accessable compared to the HP97, does anyone know of procedures to adjust the mechanicals. ie switches and eccentric cam. cheers Tony |
02-10-2019, 07:07 PM
RE: HP67 Card Reader
I set the switch bends prior to installation.
I use two instruments to adjust the cam. A very fine screwdriver can adjust the cam to a certain point. An instrument with a short 90’ bend can adjust the cam the rest of the 360 required. Geoff |
02-10-2019, 09:01 PM
I use a streched and bent paperclip. Sometimes a little bit fiddling to meet the cam slot underneath the cables.
