table data
02-22-2019, 12:23 AM (This post was last modified: 04-25-2019 02:31 AM by compsystems.)
table data
Python has an object type called DICTIONARY that in xcas / hpprime is table(), but python, only manages a few types of data in relation to xcas, which can operate with many more and powerfull math types.
Examples of use
PHP Code:
tblA := table"float_1" 5.0 "integer_2" 5"complex_4" 3+4*i"identifier_6" var01"list_7" = [9,[8,7],[6,5,4]],   "symbolic_8" x+y*"rational_9" 3/4,  "string_12" "Hello",  "set_2" seta,a],  "polynomial_10" poly11, -611, -] , "matrix" = [[1,2],[3,4]], "vector" = [9,8,7,6,5,4], "function_13" f(x):=x+1  )
enterreturns
table
tblA"float_1" ], tblA"integer_2" ], tblA"complex_4" ], tblA"identifier_6" ], tblA"list_7" ], tblA"symbolic_8" ], tblA"rational_9" ], tblA"string_12" ], tblA"function_13" ],  tblA[  "set_2" ],  tblA[  "polynomial_10" ], tblA[  "matrix"  ],  tblA[  "vector"  ]
enterreturns
5.0
,5,3+4*i,var01,[9,[8,7],[6,5,4]],x+i*y,3/4,"Hello", (x)->x+1,set[a,b,c],poly1[1,-6,11,-6],[[1,2],[3,4]],[9,8,7,6,5,4]
typetblA"float_1" ] ), typetblA"integer_2" ] ), typetblA"complex_4" ] ), typetblA"identifier_6" ] ), typetblA"list_7" ] ), typetblA"symbolic_8" ] ), typetblA"rational_9" ] ), typetblA"string_12" ] ), typetblA"function_13" ] ), typetblA[  "set_2" ] ), typetblA[  "polynomial_10"  ]), typetblA[  "matrix"  ]), typetblA[  "vector"  ]), typetblA
enterreturns
Xcas
realintegercomplexidentifiervectorexpressionrationalstringfuncvectorvectorvectorvectorDOM_MAP
hpprime
DOM_FLOATDOM_INTDOM_COMPLEXDOM_IDENTDOM_LISTDOM_SYMBOLICDOM_RATDOM_STRINGDOM_FUNC,DOM_LISTDOM_LISTDOM_LISTDOM_LISTDOM_MAP
typetblA"float_1" ] ), typetblA"integer_2" ] ), typetblA"complex_4" ] ), typetblA"identifier_6" ] ), typetblA"list_7" ] ), typetblA"symbolic_8" ] ), typetblA"rational_9" ] ), typetblA"string_12" ] ), typetblA"function_13" ] ), typetblA[  "set_2" ] ), typetblA[  "polynomial_10"  ]), typetblA[  "matrix"  ]), typetblA[  "vector"  ]), typetblA)  ] .+ 0
[enterreturns
[1,2,4,6,7,8,10,12,13,7,7,7,7,17]
tblA"list_7" ][0] [enterreturns
9
tblA
"list_7" ][[1]] [enterreturns
02-22-2019, 04:00 PM (This post was last modified: 02-22-2019 04:01 PM by toml_12953.)
RE: table() data
I get a syntax error and the cursor points after the var01 here:
tblA := table( "float_1" = 5.0 , "integer_2" = 5, "complex_4" = 3+4*i, "identifier_6" = var01
Tom L
Cui bono?
02-22-2019, 07:33 PM (This post was last modified: 04-25-2019 02:49 AM by compsystems.)
RE: table() data
Delete the space between set and the bracket []
set [] => set[], same for polynomial poly1[], I do not know why the hpprime, when pasting the data adds a space before []
Converting a rectangular array type matrix into a table
the positions start at (0,0)
Example
PHP Code:
MA:=[[9,8],
7,3+4*i]]
table(MA) [enter] returns
PHP Code:
table(
0,0) = 9,
0,1) = 8,
1,0) = 7,
1,1) = 3+4*i
for the inverse process, that is, convert a table to a matrix, Note that this must have the form
PHP Code:
table(
0,0) = element1,
0,1) = element2,
or
PHP Code:
table(
0,0] = element1,
0,1] = element2,
Example
PHP Code:
matrix
table(
0,0) = 9,
0,1) = 8,
1,0) = 7,
1,1) = 3+4*i
or
PHP Code:
matrix
table(
0,0] = 9,
0,1] = 8,
1,0] = 7,
1,1] = 3+4*i
[enter] returns
PHP Code:
[[9,8],
7,3+4*i]]
An alternative way to define tables is using ( : )
PHP Code:
:= table"foo"109:x+y*i"bar"100"baz"1000) [enterreturns
table
x+y*i,
"bar" 100,
"baz" 1000,
"foo" 10
But unlike python, Xcas reorders the labels numerically and alphabetically
To extract the tag you can use FOR
PHP Code:
for k in d:
   print(
k) [enterreturns
9
bar
baz
foo
and to access the values of the label.
PHP Code:
for k in d:
    print(
d[k]) [enterreturns
x
+y*i
100
1000
10
