Determining the Date For a Phase of Earth's Moon
02-23-2019, 04:47 PM
Introduction
The program MOONDATE determines when a desired phase of Earth's moon given month and year. The four phases of the moon available are:
New Moon (0.00)
1st Quarter (0.25)
Full Moon (0.50)
3rd Quarter (0.75)
The following equations are used:
Let y = year, m = month, t = type (see the above)
y' = y + (m -1)/12
k = integer( (y - 2000) * 12.3685) + t/4
t = k/1236.85
J = 2451550.09765 + 29.530588853 * k + (1.337 * 10^-4) * t^2 - (1.5 * 10^-7) *t^3 + (7.3 * 10^-10) * t^4
J is the Julian Date and will need to be converted to the Gregorian Date. With the DATE+ function, the HP Prime makes this easy. Look to Dieter's post on this thread for details, link: http://www.hpmuseum.org/forum/thread-121...ulian+date
Caution: This program is designed to work with all dates after January 1, 2000. If you choose any dates before, you may have to adjust the month
HP Prime Program MOONDATE
EXPORT MOONDATE()
// EWS 2019-02-19
LOCAL P,Y,K,M,T,l,c,s;
LOCAL J,D,N,R;
l:={"New","First Qtr","Full",
"Third Qtr"};
INPUT(
{Y,
{M,{1,2,3,4,5,6,7,8,9,10,11,12}}
,{c,l}},
"Moon Phase Date",
{"Year: ","Month:","Stage:"});
s:=(c-1)/4;
N:=M;
REPEAT
R:=Y+(N-1)/12;
K:=IP((R-2000)*12.3685)+s;
T:=K/1236.85;
J:=2451550.09765+29.530588853*K
+1.337ᴇ−4*T^2-1.5ᴇ−7*T^3
+7.3ᴇ−10*T^4;
J:=IP(J)-2451545;
D:=DATEADD(2000.0101,J);
N:=N+1;
UNTIL D≥(Y+M/100);
RETURN D;
Note: You can use an alternate of 1/1/2000 (date code 2000.0101) with corresponding Julian Date 2451545.
Example:
January 2019:
New: 2019.0105 (1/5/2019)
1st Qtr: 2019.0113 (1/13/2019)
Full: 2019.0120 (1/20/2019)
3rd Qtr: 2019.0127 (1/27/2019)
Source:
Meenus, Jean. "Astronomical Algorithms" Willmann-Bell, Inc.: Richmond, VA 1991 ISBN 0-943396-35-2
Blog post: https://edspi31415.blogspot.com/2019/02/...se-of.html
