Newcomer
03-06-2019, 06:50 PM
Newcomer
The tiniest 41 I ever had! :)
Greetings,
    Massimo
03-07-2019, 02:34 PM
RE: Newcomer
(03-06-2019 06:50 PM)Massimo Gnerucci Wrote:  The tiniest 41 I ever had! Smile
Cute!
03-08-2019, 01:23 AM (This post was last modified: 03-08-2019 01:25 AM by rprosperi.)
RE: Newcomer
I can't tell the scale from the photo, but if it's solid gold, I guess it's safe to conclude it's not over an inch tall... is this the same size as the 41c keychain fob?
03-08-2019, 07:25 AM
RE: Newcomer
(03-08-2019 01:23 AM)rprosperi Wrote:
(03-06-2019 06:50 PM)Massimo Gnerucci Wrote:  The tiniest 41 I ever had! :)
I don't think it's gold at all (or I'd have made a bargain).
I'll try to take measurements later today.
Greetings,
    Massimo
03-08-2019, 09:25 PM
RE: Newcomer
Not so easy to measure, being inside a plexiglass brick, but it should be around mm 28*15*2
Greetings,
    Massimo
03-10-2019, 04:53 PM
RE: Newcomer
(03-08-2019 09:25 PM)Massimo Gnerucci Wrote:  Not so easy to measure, being inside a plexiglass brick, but it should be around mm 28*15*2
Wow, even smaller than the keychain fob. That one measures mm 44 x 25 x 2.
Hard to imagine such effort was spent twice to make tiny 41C trinkets, but I'm grateful they did it, whoever it was (though almost certainly as paid by HP).
Differences:
  • Fob has function name on every key, and shifted Fn name above
  • Fob has ALPHA in bottom-right of display
  • Fob has HP logo to the left of 'Hewlett Packard' in bottom label
  • Fob has '***HP-41C***' in the display, while it appears the gold piece has '***HP-41***', but coming in 1984 there were several models then
I your tiniest 41 Massimo, gotta look for another...
