Set theory on HP Prime
05-07-2014, 02:01 AM
Hi all,
Does the prime have any facilities for dealing with sets such as union, difference, equality and such?
for example in PSUDOCODE:
{1, 2, 3} Union {2, 4, 5} = {1, 2, 3, 4, 5}
{1, 2, 3} Intersection {2, 4, 5} = {2}
{1, 2, 3} == {2, 1, 3} == TRUE
05-07-2014, 02:58 AM
RE: Set theory on HP Prime
Reading the Xcas documentation here and there is a full section on sets - tried using a similar syntax but the prime doesn't know what I'm on about. >;|
05-07-2014, 06:57 AM
Sets are supported: the infix operators are union, minus, intersect, and you should use set[ ] instead of {} or [ ] to avoid confusion with lists/vectors, e.g. for ==
set[1,2]==set[2,1]
[1,2]==[2,1]
05-07-2014, 12:35 PM (This post was last modified: 05-07-2014 12:37 PM by norlesh.)
Thanks for the reply Parisse
I just tried evaluating the following in the home screen
set[1,2]==set[2,1] ... result 1
set[1,2]==set[2,1,5] ... result 1 // WTF?
am I not understanding set theory correctly?
also every time set[..] gets evaluated it turns into set(..)
and 'set(1,2) union set(2, 1, 5)' gives a syntax error... is there any documentation?
05-07-2014, 02:53 PM
Just tried on my emulator, set[1,2]==set[2,1,5] correctly returns 0 here and set[] are not converted to set(), so perhaps this is a UI bug that has been fixed.
05-07-2014, 03:43 PM
(05-07-2014 06:57 AM)parisse Wrote:  Sets are supported: the infix operators are union, minus, intersect, and you should use set[ ] instead of {} or [ ] to avoid confusion with lists/vectors, e.g. for ==
set[1,2]==set[2,1]
[1,2]==[2,1]
Good to know! By the way, minus and union don't seem to appear in the toolbox catalog (intersect is in there, though).
05-07-2014, 03:48 PM
I have also tried out the commands mentioned by Parisse and they work correctly in CAS, but result in syntax error in Home.
A.
05-07-2014, 06:04 PM
Thanks guys - so I ran it under the CAS screen and can now confirm that set[1 2]==set[2 1 5] does indeed evaluate to zero... yey I don't have to learn a new formulation of set theory Smile
{ just to be clear though it's definately still mutzed under the home screen as of the current firmware running on a physical device - I had no idea the calculators split brain disorder ran so deep!}
05-07-2014, 06:14 PM
set[1,2]==set[2,1]
[1,2]==[2,1]
There are the standard math symbols for union and intersection in the Chars list, but they do not work as such.
05-07-2014, 07:13 PM
The HP Prime never ceases to tease me. In CAS, if I type
[1,2,3] union [2,5]
in the command line, it displays (correctly)
union( [1,2,3], [2,5]) [1,2,3,5]
But if I enter directly
in the command line, it reports syntax error.
05-08-2014, 07:03 AM
This is a textbook mode display bug, if you uncheck it in Settings, it's ok.
