HP-41 - Memory modules
04-21-2019, 03:48 PM
Post: #21
RE: HP-41 - Memory modules
(04-21-2019 03:31 PM)rprosperi Wrote:
(04-21-2019 01:52 PM)Sylvain Cote Wrote:  FYI, This is the RAM memory map for the HP-41 related to the module and memory types
A very nice (and useful) chart Sylvain, thanks for sharing this. If you have these contents in a text (or PDF, or whatever) file, suggest you post it so folks can save/print the entire thing for reference.
I will make pdf+txt files available, in the meantime you can click on the "View a Printable Version" at the bottom, do a copy/paste on the table and save it in a text file.
04-21-2019, 04:17 PM
Post: #22
(04-21-2019 03:48 PM)Sylvain Cote Wrote:  ... in the meantime you can click on the "View a Printable Version" at the bottom, do a copy/paste on the table and save it in a text file.
You're right, it works perfectly, so don't bother adding files. I did not realize the separate quoted sections would disappear in the Print view, so your suggestion is perfect (also good for future use). Thanks!
