Template for a table editor [▣=▣ ].
04-13-2019, 12:26 PM (This post was last modified: 04-19-2019 02:20 PM by compsystems.)
Hello
There is a very useful data type TABLE, it works in a similar way to the Python DICTIONARY, unlike a matrix that addresses each position by means of a "coordinate" (rows, columns), a table is addressed by a label that can be a number, a string of characters or a coordinate.
The TABLE editor is similar to the matrix editor. Simply for each position there would be two entries one for the label and one for the content.
The template for the table editor will be included in an icon next to the rest of the templates (key C / templates)
Examples
PHP Code:
tbl1:= table( (0,0)=9p1=[9,8,7], 3=-10,"b"=20,"c"=30,"d"=40,"a"=10) [enterreturns
table
= -10,
p1 = [9,8,7],
0,0) = 9,
"a" 10,
"b" 20,
"c" 30,
"d" 40
PHP Code:
tbl1["a"] [enter]  returns 10
tbl1
[3] [enter]  returns -10
tbl1
[(0,0)] [enter]  returns  9
tbl1
[p1] [enter]  returns  [9,8,7
newRPL User Manual spanish 0.1%
https://www.eonicasys.com.co/math/system...Manual_spn
04-17-2019, 03:10 PM
RE: Template for a table editor [▣=▣ ].
(04-13-2019 12:26 PM)compsystems Wrote:  Hello
Examples
tbl1:= table( (0,0)=[9,8,7], 3=-10,"b"=20,"c"=30,"d"=40,"a"=10) [enter] returns
table(
(0,0)=[9,8,7],
3 = -10,
"a" = 10,
"b" = 20,
"c" = 30,
"d" = 40
tbl1[3] [enter] returns -10
tbl1[(0,0)] [enter] returns [9,8,7]
Supposedly the TABLE command is buggy and will be deprecated at some point in the future. I can't find the thread right now but when I saw the TABLE command I got all excited until I read that it will be going away.
Tom L
Cui bono?
04-17-2019, 05:58 PM
the TABLE command works perfectly in Xcas, the problem is that in the hpprime it converts the position from (0,0) to (1,1) and then interprets it as a complex number. 1 + 1*i
https://www.hpmuseum.org/forum/thread-12793.html
04-17-2019, 10:52 PM
(04-17-2019 05:58 PM)compsystems Wrote:  the TABLE command works perfectly in Xcas, the problem is that in the hpprime it converts the position from (0,0) to (1,1) and then interprets it as a complex number. 1 + 1*i
Not that perfect. There is no way to delete (purge) table entries, for example (as far as I can tell).
— Ian Abbott
04-19-2019, 02:18 PM
Note: a coordinate as position cannot contain an array or list, to delete an element you use PURGE function
PHP Code:
table
= -10,
p1 = [9,8,7],
0,0) = 9,
"a" 10,
"b" 20,
"c" 30,
"d" 40
PHP Code:
purgetbl1["a"] ) [enter1(Done)
tbl1 [enterreturns
table
= -10,
p1 = [9,8,7],
0,0) = 9,
"b" 20,
"c" 30,
"d" 40
04-27-2019, 02:36 AM (This post was last modified: 05-20-2019 11:52 PM by compsystems.)
Another example of how to use the data in the table.
PHP Code:
phonebook := table("John":0"Jack":0"Jill":
[enter]
PHP Code:
table(
"Jack" 0,
"Jill" 0,
"John" 0
PHP Code:
phonebook["John"],phonebook["Jack"],phonebook["Jill"
[enter]
PHP Code:
0,0,
PHP Code:
phonebook["John"] := 938477566
phonebook
["Jack"] := 938377264
phonebook
["Jill"] := 947662781
[enter]
"Done","Done","Done"
PHP Code:
phonebook
[enter]
PHP Code:
table(
"Jack" 938377264,
"Jill" 947662781,
"John" 938477566
PHP Code:
[enter]
PHP Code:
938477566938377264947662781
Alternatively, a table can be initialized with the same values in the following notation:
PHP Code:
phonebook := table("John" 938477566,"Jack" 938377264,"Jill" 947662781
[enter]
PHP Code:
table(
"Jack" 938377264,
"Jill" 947662781,
"John" 938477566
Adhere to a new member.
phonebook["jaime"] := 3187935015
Iterating over tables
Tables can be iterated over, just like a list. However, a table, unlike a list, does not keep the order of the values stored in it. To iterate over key value pairs, use the following syntax:
PHP Code:
for name in phonebook:
    print(
"Phone number of " name " is " phonebook[name])
[enter]
PHP Code:
Phone number of Jack is 938377264
Phone number of Jill is 947662781
Phone number of John is 938477566
Removing a value
To remove a specified index, use either one of the following notations:
PHP Code:
del phonebook["John"
[enter]
phonebook [enter]
PHP Code:
table(
"Jack" 938377264,
"Jill" 947662781
or
PHP Code:
phonebook.pop("Jill"
[enter]
phonebook [enter]
PHP Code:
table(
"Jack" 938377264
