Question regarding ICON
04-27-2019, 09:03 PM
Does anyone know how to use ICON and hex png files for the HP Prime? Thanks in advance.
04-28-2019, 04:47 AM
RE: Question regarding ICON
(04-27-2019 09:03 PM)Eddie W. Shore Wrote: Does anyone know how to use ICON and hex png files for the HP Prime? Thanks in advance. You can find more info here: https://www.hpmuseum.org/forum/thread-113.html I do not recommend using ICON because there is now direct support for PNG and JPG files. It is outdated and was mainly used to import sprites (small pictures). The link above also references a zip file that has a utility for creating the data after the ICON command. Once you see the huge data, though, you will likely agree that ICON is not so useful these days due to the inflated size of your programs (the data is ASCII representation of the hex data). Graph 3D | QPI | SolveSys |
