Favorite Fluids for fluid changes on Calcs
05-11-2014, 02:45 PM
(This post was last modified: 05-11-2014 02:58 PM by Vagn Anderssen.)
For fluids change, what is your preference?
This is a 100% critical process, often overlooked. You fluids change your Saab or Volvo or Maserati, why neglect your calcs???? I use: Armour all Ultra Shine as a finisher. Pro-Gold for gold contact enhancement http://www.deoxitgold.com/?progold_info=1 ClearAudiio UHE Contact Cleaner http://www.elusivedisc.com/CLEARAUDIO-CL...CLEACLEAN/ High end Rubber cleaner: http://www.detailedimage.com/Meguiars-M4...2/16oz-S1/ In reverse order First, you use the Clearaudio to clean it the contacts of all sorts, then the Pro-Gold on the contacts (e.g. for where you plug modules into the 41/71/48 etc) Then clean the rubbers. then detail the calc first with soft contact cleaner then the high gloss. Finally, if you can find it, use O2 blocker on the interior: http://articles.courant.com/1997-03-06/e...o2-blocker This REVERSES oxidation. Great on older units. even makes the keys snappier. Next gentle starch lubricant applied with a cloth on rails and hinges for modules. Use any high end one of your choice. Finally, AAA Lithiums are a must when useable. Vagn |
