Hp 39gii integration fail
05-12-2014, 03:00 AM
The function 3*x^(2/3)-2*x graphs fine, d/dx set to zero in solve app finds extremum at (1,1).
When integrating, regardless if I use x^(2/3) or 3 root x fails.
In the plot, area under curve from 0 to 3.375 yield an answer ~.08+ vs? real answer of ~2.28.
Is this a bug?
05-12-2014, 03:41 AM
RE: Hp 39gii integration fail
Side note...same function integrates fine away from 0.
Integrating 3*x^(2/3)-2*x from 1 to 2 gives correct .91464378706 11 digit answer in ~5 seconds.
Integrating same function written as 3*(3 root x)^2-2*x gives same answer in ~21 seconds.
Taking area under curve in plot app from 1 to 2 gives same correct 11 digit answer almost instantaneously!
05-12-2014, 04:50 AM (This post was last modified: 05-12-2014 04:51 AM by kakima.)
I'm not quite duplicating your results.
On the home screen, integrating from 0 to 3.375 my 39gII gives me the ~2.28. In the function app, the signed area from 0 to 3.375 gives me "Undefined." Going from 0.001 to 3.375 gives me ~2.28.
Edit: I do get your results integrating from 1 to 2.
