HP-41 Card Reader Question
05-16-2019, 07:30 AM
On the picture you see a card reader with …A… in the Serial Number. Means it should manufactured in America.
The label indicates MADE IN SINGAPORE
What is correct???
[Image: cr.jpg]
05-16-2019, 05:25 PM (This post was last modified: 05-16-2019 05:27 PM by Zaphod.)
RE: HP-41 Card Reader Question
(05-16-2019 07:30 AM)CY-CL Wrote:  On the picture you see a card reader with …A… in the Serial Number. Means it should manufactured in America.
What is correct?
Maybe it’s been opened and repaired and the wrong label/sheet reapplied ?
Certainly looks like it’s been removed and replaced.
Does it matter that much ?,....
.... if it works then....
05-16-2019, 08:11 PM (This post was last modified: 05-16-2019 08:11 PM by burkhard.)
What is correct???
There is a lot of what looks like glue-gunk around the label. I would assume somebody trashed the original label opening it up and replaced it with a recycled label.
I certainly would trust the imprinted s/n a lot more than the sticker which could be swapped in a minute or two.
05-16-2019, 08:33 PM
I guess, I have to formulate my question differently. Has anyone ever seen a Card Reader with a US label? Does anyone have a picture of it?
Many thanks.
05-16-2019, 10:07 PM
(05-16-2019 08:33 PM)CY-CL Wrote:  Has anyone ever seen a Card Reader with a US label? Does anyone have a picture of it?
I have several, have a look at this one.
05-16-2019, 10:30 PM
I have one, S/N 2019A00104, my original unit from 1980. The label is identical to Sylvain's example, except that either his or my label is upside down. My label is oriented the same as shown in the OP photo, which I think is correct/original, but this is my only card reader and it was rebuilt around 2013, so it could have been reinstalled wrong.
05-16-2019, 11:43 PM
On the 12 to 15 card readers that I have, most are on the same side of you guys and not like the picture that I have shared.
05-17-2019, 06:54 AM
Thats great. Many thank Sylvain to share the picture.
(05-16-2019 11:43 PM)Sylvain Cote Wrote:  On the 12 to 15 card readers that I have, most are on the same side of you guys and not like the picture that I have shared.
