(HP-97) Design one-shot multivibrators
05-21-2019, 03:31 PM
(This post was last modified: 05-24-2019 11:14 PM by SlideRule.)
Designing or analyzing timing circuits that use the popular 74123 one-shot multivibrator (Fig. 1) will be much quicker on a programmable calculator. The program shown in Fig. 2 will run on either an HP-67 or HP-97 calculator. However you can easily program other calculators to solve a basic timing equation, with which you can closely approximate a one-shot's timing curve
T = 0.32 (R ÷ 0.7)C + 11.8 R0.837 where T is the pulse duration (nS), R is the resistance (kΩ) C is the capacitance (pF), as in Fig. 1. [attachment=7276] 1. A one-shot multivibrator, based on the 74123 IC has three basic parameters. If you know two of them you can calculate the third from an equation that approximate the timing curve. Given any two or the three parameters, you can calculate the third. The equation is accurate for all values of C. The calculator program employs a recursive method with three iterations to solve for resistance. To use the program first enter known parameter, then its user-defined key. Then depress the key set aside for the unknown parameter. If any of the components are outside recommended limits, an error signal will be displayed. Fig. 2 001*LBL E <>nS 002 STO E 003 F3? 004 RTN 005 GSB 2 006 RCL C 007 × 008 GSB 1 009 + 010 STO E 011 SCI 012 DSP 1 013 RND 014 FIX 015 DSP 0 016 RTN 017*LBL 1 018 RCL D 019 . 020 8 021 3 022 7 023 Y^X 024 1 025 1 026 . 027 8 028 × 029 RTN 030*LBL 2 031 . 032 7 033 RCL D <>kΩ 034 + 035 . 036 3 037 2 038 × 039 RTN 040*LBL C 041 ENT↑ 042 FRC 043 X=0? 044 GTO C 045 CLX 046 EEX 047 6 048 × 049 ENT↑ 050*LBL C <>pF 051 R↓ 052 STO C 053 F3? 054 RTN 055 RCL E 056 GSB 1 057 - 058 GSB 2 059 ÷ 060 STO C 061 . 062 9 063 X⇄Y 064 X≤Y? 065 GTO e 066 FIX 067 DSP 0 068 RTN 069*LBL D 070 STO D 071 F3? 072 GTO D 073 3 074 STO I 075 1 076 0 077 STO D 078*LBLd 079 GSB 2 080 RCL C 081 × 082 GSB 1 083 + 084 RCL E 085 X⇄Y 086 ÷ 087 RCL D 088 × 089 STO D 090 DSZ I 091 GTO d 092*LBL D 093 4 094 . 095 9 096 X⇄y 097 X≤Y? 098 GTO e 099 5 100 0 101 X⇄Y 102 X>Y? 103 GTO e 104 DSP 1 105 RTN Historical significance? BEST! SlideRule Source: 400 Ideas for Design (Calculator/Computer Circuits & Software) listing corrected, thanks mfleming. |
05-24-2019, 01:19 AM
(This post was last modified: 05-24-2019 11:04 PM by mfleming.)
RE: (HP-97) Design one-shot multivibrators
I see a couple of errors in the listed program. In program step 18, the command should be "RCL D" (the resistor value) rather than "RCL1". For steps 31 to 33, the operations should be reversed so that you do "RCL D" first then ".7" afterwards. Finally, to match the equation, line 34 should be "/" (divide) rather than "+".
Here's the modified program listing (with keycodes) in "Teenix" format Code:
Remember kids, "In a democracy, you get the government you deserve." |
05-24-2019, 01:06 PM
Flemming
Could you please give as an example and a sequence of instructions Thank you in advance, Pedro |
05-24-2019, 03:40 PM
original attached
[attachment=7310] BEST! SlideRule |
05-24-2019, 11:02 PM
Thanks for the source SlideRule! Is it from volume 1 of the series? Abe Books only turns up volume 4 (1980) in quantity at a dizzying price, along with two that may be first edition (1964). I can remember browsing Electronic Design and other magazines at the library as an undergraduate looking for ideas like this one...
Looks like the original equation is $$T = 0.32(R+0.7)C + 11.8(R^.837)$$ So the addition operator in step 34 is correct. Step 18 is RCL D as noted, and step 61 should be a decimal point rather than the subtraction operator. Here's a correction in "Teenix" format with key codes for the HP-67 (I have no HP-97, and given the price on TAS, I'm very likely never to have one ) The updated ZIP file from my previous post contains the same listing along with the program card to load into the Teenix HP-67 emulator. Code:
Pedro, an example would be something like this. You'd like a 100 nSec pulse from a one-shot, so you'd start with a one puff cap as a good guess and enter into the calculator 100 "E" (enter value of pulse time in nanoseconds) 1 "C" (enter value of capacitance in picoFarads) "D" (calculate value of resistor in kiloOhms) 12.2 (displayed result) Given that era, you were probably working with 10% resistor values (5% for military, 1% for NASA!). Values in the E12 series are 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 times a decade multiplier So the best resistor value would be a 12 Kohm, 10% resistor. If on the other hand suppose you wanted a 250 ns pulse. Enter the known value T and a guess for C. 250 "E" (New pulse time, 250 ns) 1 "C" (starting value for C) "D" (calculate resistor value) Displays 36.1 (KOhms) The calculated resistor value (36.1 Kohm,) doesn't fit well in the above E12 series. Try using the next two decade values for capacitance, 10pF and 100pF. 250 "E" (nSec) 10 "C" (pF) "D" Displays 24.2 (KOhm) 250 "E" (nSec) 100 "C" (pF) "D" Displays 5.6 (KOhm) A 100pF capacitor gives a resistor value of 5.6KOhms and that is right on the nose in the E12 series. Now imagine doing this trial and error process with a slide rule or non-programmable calculator! ~Mark Remember kids, "In a democracy, you get the government you deserve." |
05-24-2019, 11:21 PM
Dear Flemming. I always ask for a numeric example for three simple reasons: a) to check programming (my wrong keystroking or programmer failures), b) to learn about the subject and its sensitivity, and c) to get the correct units (for in and outputs) and procedure instructions (not always clear for me)
Thank you a lot, Pedro |
