(newRPL) Toggle Rectangular / Polar Display
06-12-2019, 10:23 PM
This is a little library implementing a toggle which alternates display of complex number on level 1 of the stack in rectangular or polar coordinate system.
It takes advantage of the possibility to assign new definitions not only to keys, but also to events associated to a key such as "key pressed" or "key released".
In particular, given a complex number on level 1, if the toggle key is pressed, and as long as it is pressed, its representation will switch to rectangular if originally in polar and vice versa.
When the toggle key is released, it will switch back to normal.
The library consists of two commands: "INSTTOG" and "UNINSTTOG" which, as their name suggest, are used to bind/unbind the toggle to your favourite key.
Both commands accept a string description of they key to which the toggle is associated, in the ASKKEY command format.
For example, if you want to associate the toggle to unshifted "." (dot) you must run
"DT." INSTTOG
To uninstall the toggle
"DT." UNINSTTOG
Here is the code of the library
"TOGGLE RECT/POLAR DISPLAY v1.0
(c) Stefano Priore 2019"
'$TITLE' STO
'$IGNORE' STO
  { 'INSTTOG' 1 0 "Bind toggle to a key
S →" }
{ 'UNINSTTOG' 1 0 "Remove toggle asn from key
S →" }
'$VISIBLE' STO
'TRPD'
'$LIBID' STO
    k « k IF
     DUPDUP TYPE
     24 == SWAP "" ≠
     AND
    THEN
     DUP ASSN 1 GET SWAP
     ".L" + 0 ASNKEY
     ASSN 2 GET SWAP
     ".U" + 0 ASNKEY
     0 KSTO 0 TSTO
    ELSE
      24 DOERR
    END
'INSTTOG' STO
    k « k IF DUPDUP TYPE
    24 == SWAP "" ≠
    AND THEN
      DUP ".L" + DELKEY
      ".U" + DELKEY
    ELSE
      24 DOERR
    END
'UNINSTTOG' STO
    IF
     DEPTH
    THEN
     IF
      DUP TYPE 30 ==
     THEN
      IF
       DUP TYPEE FP
      THEN
       DUP TSTO 1 KSTO →RECT
      ELSE
       DUP TSTO 1 KSTO →POLAR
      END
     END
    END
    IF
     KRCL
    THEN
     DROP TRCL 0 KSTO
    END
'ASSN' STO
  'KPRESS' LIBSTO
'KSTO' STO
  'KPRESS' LIBRCL
'KRCL' STO
  'TEMP' LIBSTO
'TSTO' STO
  'TEMP' LIBRCL
'TRCL' STO
Attached File(s)
.zip  TRPD.zip (Size: 590 bytes / Downloads: 4)
09-26-2020, 02:07 PM
RE: (newRPL) Toggle Rectangular / Polar Display
It works perfectly ;D
