[WP-34s] Swap question
05-16-2014, 01:36 PM
(This post was last modified: 05-16-2014 01:50 PM by Tugdual.)
I'm having some difficulties to understand how the "pure" P.FCN swap function (looks like two opposite arrows one on top of the other with no register indication).
Is that used to swap two non stak registers like R11<->R12? What would be the keyobaord entry? Apparently it would only accept XYZT but expects 4 letters? Finally is it possible to have indirect swap? Something like: Code: R10=8, R11=9 R8=3, R9=4 Edit: Ok found the command P.FCN<-> page 113 of doc 3.1. So that's not what I'm looking for. Is there a way to swap registers and indirect registers? There is still R-SWAP but a bit cumbersome with the required real value parameter. |
05-16-2014, 02:06 PM
(This post was last modified: 05-16-2014 02:07 PM by Didier Lachieze.)
RE: [WP-34s] Swap question
(05-16-2014 01:36 PM)Tugdual Wrote: Finally is it possible to have indirect swap? You can do that with 3 instructions: Code: h x<> -> 10 At the end the content of registers R8 and R9 has been swapped and the stack is unchanged. |
05-16-2014, 02:12 PM
(This post was last modified: 05-16-2014 02:14 PM by Tugdual.)
(05-16-2014 02:06 PM)Didier Lachieze Wrote:Very smart!(05-16-2014 01:36 PM)Tugdual Wrote: Finally is it possible to have indirect swap? Thanks Didier! Is that the same as: Code: RCL ->10 |
05-16-2014, 02:38 PM
(05-16-2014 02:12 PM)Tugdual Wrote: Is that the same as:It's the same for the registers content but not for the stack content. My sequence leave the stack unchanged. Your sequence change the content of the stack: - let say you have a 4-depth stack: X, Y, Z, T - after your sequence the stack content will be: R9, X, Y, Z |
05-16-2014, 02:40 PM
(05-16-2014 02:38 PM)Didier Lachieze Wrote:(05-16-2014 02:12 PM)Tugdual Wrote: Is that the same as:It's the same for the registers content but not for the stack content. My sequence leave the stack unchanged. Your sequence change the content of the stack: Good point. Thanks for mentioning this. |
