(11C) Distance, Speed and Time
07-13-2019, 06:30 AM
(This post was last modified: 07-14-2019 03:49 AM by Gamo.)
Program to calculates the Distance (d), Speed (s), or Time (t)
for a moving body according to the following formulas: d = st [distance = speed x time] s = d/t [speed = distance ÷ time] t = d/s [time = distance ÷ speed] Given any two of the quantities d, s and t, the program will calculate the third. --------------------------------------- Remark: This program was adapted from HP-97 Owner's Handbook page 235 Since HP-11C doesn't have the special "test-clearing feature of data entry" so this program use Conditional Test to simulate Data Entry Flag. -------------------------------------- Procedure: [A] Distance [B] Speed [C] Time Example: Fix 4 Distance = 3500 miles Speed = 2070.101 miles per hour Time = ? 3500 [A] display 0.0000 2070.101 [B] display 0.0000 [C] display answer 1.4127 // Time is 1 hour, 41 minutes, 27 seconds ----------------------------- Speed = 95 kilometers per hour Time = 48 hours Distance = ? 95 [B] display 0.0000 48 [C] display 0.0000 [A] display answer 4560.0000 kilometers // Distance --------------------------- Distance = 1.5 kilometers Time = 0.03349 // 3 minutes, 34.9 seconds Speed = ? 1.5 [A] display 0.0000 .03349 [C] display 0.0000 [B] display answer 25.1280 Kilometers per hour // Speed -------------------------- Program: [ , ] is a decimal point Code:
Gamo |
07-14-2019, 11:00 AM
(This post was last modified: 07-15-2019 01:24 AM by Gamo.)
RE: (11C) Distance, Speed and Time
This add-on program option for Distance, Speed and Time from previous post
Added the Distance or Speed for the units conversion between Mile and Kilometer Previous Program calculate Distance, Speed or Time using these Labels [A] Distance [B] Speed [C] Time mile and kilometer conversion [D] Mile to Kilometer [E] Kilometer to Mile Program: recommend FIX 2 precision Code:
Procedure: Mile [D] display Kilometer Kilometer [E] display Mile ---------------------------- Gamo |
07-15-2019, 12:43 AM
(This post was last modified: 07-15-2019 04:08 AM by Gamo.)
Example using Google Map:
According to the information from Google Map Distance from Los Angeles to Las Vegas is 269.4 mile Approximate time of arrival is 3 hour and 49 minute What is the speed according to this information? What is the speed answer in kilometer per hour? If speed change to 90 mile per hour, how long it take to get to Las Vegas? ------------------------------- Procedure: FIX 2 Distance: 269.4 mi Time: 3 h 49 min Speed: ? 269.4 [A] display 0.00 3.49 [C] display 0.00 [B] display 70.59 Answer: Speed is 70 mile per hour --------------------- Change unit from mile per hour to kilometer per hour Previous mil/hr answer on display [D] display 113.60 Answer: 114 kilometer per hour -------------------- Speed change to 90 mile per hour what is the time? 90 [B] display 0.00 [C] display 2.59 Answer: 3 hour Increasing speed from 70 to 90 mil/h the arrival time will be about 50 minutes faster. The recommended speed from Google Map is 70 mil/h that is based on California freeway speed limit. -------------------- Remark: Please drive according to the Speed Limit in your area to avoid unwanted speeding ticket !!! Gamo |
07-15-2019, 02:52 AM
(07-15-2019 12:43 AM)Gamo Wrote: Please drive according to the Speed Limit in your area Here is another reason: The physics of speeding cars Quote:The risk of being in a serious car crash doubles for every 5 km/hr over 60 |
07-15-2019, 03:50 AM
(This post was last modified: 07-15-2019 04:18 AM by Gamo.)
Thanks Albert Chan
Good detail information. Before in California most Freeway posted 65 mil/hr speed limit but nowadays changed to 70 mil/hr (Even in the old days posted 55 mil/hr) No wonder that Google Map calculate Distance and Time based on 70 mil/hr speed. ------------------------- With Google Map again from Los Angeles to New York Distance = 2789.5 mi Time = 41 hr The speed is 68 mil/hr // Assume that continue driving none stop to destination Gamo |
07-17-2019, 01:39 AM
This program used Flags just like the example shown here for HP-65
Distance, Speed and Time using Flags in program. https://www.hpmuseum.org/forum/thread-13290.html Gamo |
07-18-2019, 11:30 AM
This version work the same as the HP-65 program example above.
Program make used of the Subroutine, Flags and Indirect Line Number Branching. The main focus on this program is the Indirect Line Number Branching. I don't see people using this feature much and HP-11C User's Handbook doesn't give program example on this feature. -------------------------------- Procedure: USER mode 1. Initialize [A] 2. Input any two of [B] [C] [D] 3. To calculate [E] the Unknown [B] [C] or [D] -------------------------------- Program: Code:
Gamo |
